Aller au contenu principal
Razer Barracuda X Volume Control Knob Replacement
Roman Walker
Roman Walker et un autre contributeur
Dernière mise à jour le January 7, 2025
15 minutes
Modérée
This page is for the Razer Barracuda X. The guide is for the Volume Control Knob.
Make sure the device is fully off, and the device is not being charged.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Razer Barracuda X Volume Control Knob Replacement, Battery: étape 1, image 1 de 3 Razer Barracuda X Volume Control Knob Replacement, Battery: étape 1, image 2 de 3 Razer Barracuda X Volume Control Knob Replacement, Battery: étape 1, image 3 de 3
    • Remove the cushion by pulling it off from the edge and out from the grooves.
    • Continue to pull the cushion away from the speaker until the cushion is fully separated.
  2. Razer Barracuda X Volume Control Knob Replacement: étape 2, image 1 de 1
    • Remove the four 6 mm Phillips #1 screws from the left side of the speaker casing.
  3. Razer Barracuda X Volume Control Knob Replacement: étape 3, image 1 de 2 Razer Barracuda X Volume Control Knob Replacement: étape 3, image 2 de 2
    • Gently pull the speaker casing away from the shell.
    • Place it face down to access the battery.
  4. Razer Barracuda X Volume Control Knob Replacement: étape 4, image 1 de 2 Razer Barracuda X Volume Control Knob Replacement: étape 4, image 2 de 2
    • Unplug the battery from the socket.
    • Use a spudger to gently lift the battery up.
    • Remove the battery.
    What's battery used in this headphones?
    govno - Réponse
  5. Razer Barracuda X Volume Control Knob Replacement, Ear Pad: étape 5, image 1 de 1
    • Remove the old cushion by pulling it off from the edge and out from the grooves.
  6. Razer Barracuda X Volume Control Knob Replacement: étape 6, image 1 de 1
  7. Razer Barracuda X Volume Control Knob Replacement, Microphone: étape 7, image 1 de 1
    • Unplug the microphone from the headset.
  8. Razer Barracuda X Volume Control Knob Replacement, Volume Control Knob: étape 8, image 1 de 1
    • Remove four 6 mm Phillips #1 screws that secure the cover.
    • Lift off the cover.
  9. Razer Barracuda X Volume Control Knob Replacement: étape 9, image 1 de 1
    • Remove the single 6 mm Phillips screws that secures the volume control knob.
  10. Razer Barracuda X Volume Control Knob Replacement: étape 10, image 1 de 1
    • Remove the volume control knob.
Roman Walker
Membre depuis le 09/23/24
97 Réputation
1 tutoriel rédigé
Équipe
3 commentaires de tutoriel
Right ear stops playing when I set volume to max, and crusting noises when I change the volume. I suppose it's because of dirty potentiometer, just going through these steps and cleaning it with alcohol should work right?
Kisoma - Réponse
Could you tell me where I can get a potentiometer for these headphones? 102b that they don’t fit on aliexpress because the sound from the parav is lost
Сергій Хлевнюк - Réponse
could you tell me the measurements for the knob? Mine broke from being o tightened too much and use, so I wanted to 3d print a replacement
oviel rosario - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 17
30 derniers jours : 77
Total : 480
