Aller au contenu principal
Remplacement de la batterie de l'iPhone X
Ce dont vous avez besoin
Vidéo d'introduction
  1. Remplacement de la batterie de l'iPhone X, Vis Pentalobe: étape 1, image 1 de 1
    • Avant de commencer, déchargez votre iPhone en dessous de 25 %. Une batterie lithium-ion chargée peut prendre feu et/ou exploser si elle est accidentellement percée.
    • Éteignez votre iPhone avant de commencer à le démonter.
    • Dévissez les deux vis Pentalobe de 6,9 mm en bas de l'iPhone.
    • Si les vis sont dénudées ou endommagées, remplacez-les.
    • Ouvrir votre écran iPhone X va endommager ses joints étanches. Pensez à vous procurer des joints de remplacement avant de vous lancer dans une réparation iPhone, ou bien faites attention à ne plus exposer votre iPhone à des liquides si vous le remontez sans changer les joints.
    There are 6.81mm long screws!
    Daniel - Réponse
    One of the pentalobe screws is stripped :( - suggestions for how to get it out?
    cgtyoder - Réponse
    same situation here
    kaunomarcius - Réponse
    Same issue for me too, how do I get the stripped screw out?
    patronics - Réponse
    Update: I was able to get the “stripped” screw out using another Pentalobe-2 screwdriver bit from another company. It seems it wasn’t the screw, but the screw driver that was actually stripped. Hence why the other screwdriver kit I got came with 3 of this bit, I suppose.
    patronics - Réponse
    I ended up going to a jewelry store, and they drilled down into the screw, with of course an incredibly tiny bit. That allowed me to insert the P2 driver, and I was able to unscrew it at that point. Good luck!
    cgtyoder - Réponse
    Same issue with the stripping. The tip of the iFixit P2 head in my $70 kit just ground off on the first screw and that was that. Not much you can do.
    Kyle Harris - Réponse
    yes correct the same happened to me, the screws were perfect shaped never been open and as soon as i used the P2 it stripped the screws, seems like the P2 is slightly smaller but Dremel kit with a very small drill bits and precise knife tool is the way to go.
    Dulce Vidal - Réponse
    This step in automatically followed through, without any thought. Why remove these screws? Can anybody explain? The Screen is detachable all the same, with them well screwed in…
    Uri - Réponse
    These screws attach to a plate that’s part of the screen half of the phone. If you succeed in detaching the screen without removing those, it would seem reasonable that you will have damaged that plate or its ability to keep the two halves together.
    Dan Long -
    @Dan Long is right
    Uri -
    Clean out the pentalobe screw heads first so the tool goes all the way in. A small sewing needle works well to loosen any build up and then press some putty/chewing gum into the screw head and pull away quickly for a final clean out.
    William Olstad - Réponse
    The this kit should include screws because you’re going to strip them. Can’t even get past step one. Did anybody figure this out
    justin - Réponse
    Never opened my phone ever, when I went to look at the first step.. I noticed one of my screws was stripped. I thought it was impossible, but I removed the non stripped one, then once I got to the stripped one.. I learned my assumptions were correct. I bought this one straight from the apple site years ago ahaha Any tips to remove the stripped screw?
    Clarence Williams - Réponse
    William Olstad's tip about cleaning the screws with a needle and a bit of poster putty worked well for me. There was a lot of crud in there! The opening is shallow, so it's easy to see how the screwdriver wouldn't catch with even a bit of grit in the way, No problem getting the pentalobe screws out with the ifixit screwdriver.
    punkinann - Réponse
    If all else fails, very carefully cut a slot across the head of the screw with a Dremel tool using a diamond bit that dentist will gladly give you - I ask my dentist for used bits; and chuck them in a drill bit chuck designed for Dremel. The slot allows you to use a tiny, straight blade screwdriver. You can reuse the screw or replace it with a new pentalobe screw.
    Dan Smith - Réponse
  2. Remplacement de la batterie de l'iPhone X, Marquer vos médiators: étape 2, image 1 de 3 Remplacement de la batterie de l'iPhone X, Marquer vos médiators: étape 2, image 2 de 3 Remplacement de la batterie de l'iPhone X, Marquer vos médiators: étape 2, image 3 de 3
    • S'il est inséré trop loin, un médiator risque d'endommager votre appareil. Suivez cette étape pour tracer un repère sur votre médiator et éviter que l'appareil ne soit endommagé.
    • Mesurez 3 mm à partir de la pointe et tracez une ligne sur le médiator avec un marqueur permanent.
    • Vous pouvez également marquer les autres coins du médiator avec des mesures différentes.
    • Une autre solution consiste à scotcher une pièce de monnaie sur votre médiator, à 3 mm de la pointe.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Réponse
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Réponse
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Réponse
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Réponse
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - Réponse
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - Réponse
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - Réponse
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - Réponse
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - Réponse
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - Réponse
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - Réponse
  3. Remplacement de la batterie de l'iPhone X, Recouvrir toutes les fissures: étape 3, image 1 de 3 Remplacement de la batterie de l'iPhone X, Recouvrir toutes les fissures: étape 3, image 2 de 3 Remplacement de la batterie de l'iPhone X, Recouvrir toutes les fissures: étape 3, image 3 de 3
    • Si votre écran iPhone X est fissuré, empêchez les fissures de s'aggraver et les éclats de vous blesser en le recouvrant de ruban adhésif.
    • Recouvrez l'écran de bandes de ruban adhésif, qui se chevauchent, jusqu'à ce que toute la surface soit couverte.
    • Portez des lunettes de sécurité pour vous protéger les yeux des éclats de verre tout au long de la réparation iPhone.
    • Si la ventouse n'adhère pas au cours des étapes suivantes, pliez un morceau de ruban adhésif épais (du ruban adhésif toilé p.e.) pour former une poignée et soulevez l'écran de cette façon.
    • Si tout cela échoue, vous pouvez coller la ventouse à l'écran avec de la superglue.
  4. Remplacement de la batterie de l'iPhone X, Instructions Anti-Clamp: étape 4, image 1 de 3 Remplacement de la batterie de l'iPhone X, Instructions Anti-Clamp: étape 4, image 2 de 3 Remplacement de la batterie de l'iPhone X, Instructions Anti-Clamp: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Clampy - Anti-Clamp
    $24.95
    • Les trois étapes suivantes sont consacrées à la procédure avec l'Anti-Clamp, un outil facilitant les procédures d'ouverture. Si vous n'avez pas d'Anti-Clamp, passez à la procédure alternative trois étapes plus loin.
    • Pour des instructions complètes sur comment utiliser l'Anti-Clamp, jetez un œil à ce tutoriel.
    • Tirez la poignée bleue vers l'arrière pour débloquer les bras de l'Anti-Clamp.
    • Insérez le côté droit ou gauche de votre iPhone entre les bras.
    • Positionnez les ventouses en bas de l'iPhone, une sur le dessus, l'autre en dessous.
    • Appuyez sur les deux ventouses pour qu'elles adhèrent bien.
    • Si vous trouvez que la surface de votre appareil est trop glissante pour que l'Anti-Clamp puisse adhérer, vous pouvez utiliser du ruban adhésif pour créer une surface plus adhérente.
  5. Remplacement de la batterie de l'iPhone X: étape 5, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 5, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 5, image 3 de 3
    • Tirez la poignée vers l'avant pour bloquer les bras.
    • Tournez la poignée dans le sens des aiguilles d'une montre, de 360 degrés ou jusqu'à ce que les ventouses commencent à s'étirer.
    • Vérifiez que les ventouses restent bien alignées entre elles. Si elles commencent à se décaler, détachez-les pour les réaligner.
  6. Remplacement de la batterie de l'iPhone X: étape 6, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 6, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 6, image 3 de 3
    • Chauffez un iOpener et faites-le passer à travers les bras de l'Anti-Clamp.
    • Vous pouvez également utiliser un sèche-cheveux, un pistolet à air chaud ou une plaque chauffante. Mais gare à la surchauffe, l'écran et la batterie sont sensibles à la chaleur. Faites donc bien attention.
    • Pliez l'iOpener de façon qu'il repose sur le bord inférieur de l'iPhone.
    • Attendez une minute que l'adhésif se ramollisse et qu'un espace s'ouvre.
    • Insérez un médiator sous l'écran et le joint en plastique, et non dans l'écran.
    • Si l'Anti-Clamp n'a pas créé un écart suffisamment large, appliquez plus de chaleur sur la surface et tournez la poignée d'un demi-tour de plus.
    • Ne tournez pas plus d'un demi-tour à la fois, et attendez une minute entre chaque rotation. Laissez l'Anti-Clamp et le temps faire le travail pour vous.
    • Passez les trois étapes suivantes.
    DO NOT separate the glass from the plastic bumper or rim around it. These instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body. It is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - Réponse
    Thanks for pointing this out! I'll revise this step to clarify this point.
    Arthur Shi -
  7. Remplacement de la batterie de l'iPhone X: étape 7, image 1 de 1
    • Chauffer le bord inférieur de l'iPhone va aider à ramollir l'adhésif qui fixe l'écran, et donc faciliter l'ouverture.
    • Utilisez un sèche-cheveux ou un pistolet à air chaud ou préparez un iOpener et appliquez-le sur le bord inférieur de l'iPhone pendant environ une minute afin de ramollir l'adhésif qui se trouve en dessous.
    • Si vous utilisez un sèche-cheveux ou un pistolet à air chaud, ne chauffez pas trop, car vous risqueriez de détériorer l'écran.
    General tip regarding heating necessary to remove adhesive:
    consider using a heated tip of a small screwdriver or metal spudger (not the one made of plastic, provided in kit), rather than to heat the device itself.
    Uri - Réponse
    You then need to be careful about the temp of the tool which if hot enough can melt plastic components or harm them. Keeping the heat source (heat gun) far enough away from the object that you’ll eventually melt the glue but would be much harder to melt components. I try to keep 4” or 5” gap between the source & object
    Sandman619 -
    Thanks for the info. Could a air convector do the job
    dominique.br - Réponse
    When opening a device that has previously been worked on, and on which the adhesive might not have been replaced, be extremely carful when opening the phone. It will open much more easily than expected. If you’re not careful you might rip a cable.
    jonpol - Réponse
    Is this tool required or can I just use the Anti-Clamp by itself.
    Mikail - Réponse
    If you have a 3d printer, heat the bed to 80c and put the phone screen side down on it for 30 secs
    philip.joseph123 - Réponse
    thaks for this advise, I was looking for this as I dont have a heat gun haha, nice hack
    Andres Chaparro -
  8. Remplacement de la batterie de l'iPhone X: étape 8, image 1 de 2 Remplacement de la batterie de l'iPhone X: étape 8, image 2 de 2
    • Si vous utilisez une ventouse simple, posez-la au niveau du bord inférieur du téléphone tout en évitant la partie incurvée du verre.
    If you were using some form of screen protector, it may come off first as soon as you pull on the suction cup. Do not be alarmed. That is normal behavior.
    Alain-Daniel Wa-Baguma - Réponse
    3m VSB double stick tape will stick to the screen when the suction cups fail (see my comment on step 1)
    Tawan Khamapirad - Réponse
  9. Remplacement de la batterie de l'iPhone X: étape 9, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 9, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 9, image 3 de 3
    • Tirez fermement sur la poignée de la ventouse en appliquant une pression constante, pour ouvrir une petite fente entre l'écran et le châssis.
    • Insérez un médiator dans l'espace sous le joint en plastique de l'écran, pas dans l'écran lui-même.
    • L'adhésif étanche qui maintient l'écran est très solide ; ouvrir cette première fente nécessite beaucoup de force. Si vous avez du mal à le faire, chauffez le tout encore une fois. Puis faites doucement basculer l'écran de haut en bas pour faire céder l'adhésif, jusqu'à que vous ayez ouvert une fente suffisamment large pour y insérer le médiator.
    In addition to safety goggles, I would recommend you also wear good gloves to avoid getting cut with the glass as you try to pry it open.
    The top about applying more heat and gently rocking the screen up and down to weaken the adhesive did the trick for me. Thank you!
    Monil Shah - Réponse
    There needs to be more clarity on where to shove the opening pick into. There is actually two openings that the pry tool can be forced into: one below the black plastic bezel, and one above the black plastic bezel. When I heated my screen with a warming pad and pulled up the suction cup, it actually pried apart above the black plastic bezel which removed the touch screen from the display panel. With this being the first newer iPhone I'd opened since the 3GS, I didn't realize that I was opening the wrong opening as the directions only mentioned one opening and did not warn of this. I was pretty disappointed in the lack of mentioning this, as I was taking my time and following it to the tee. As a result, it destroyed my original iPhone screen.
    Caleb Davison - Réponse
    DO NOT separate the glass from the plastic bumper or rim around it. As someone else noted, these instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body of the phone. When pulling upwards with the suction cup, it is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - Réponse
    Thank you for pointing this out! I've updated the step to reflect this.
    Arthur Shi -
    The suction cup doesn't work at all... The minimum force I apply to lift it up, it comes off completely. This is very frustrating!!!
    Mario Silva - Réponse
  10. Remplacement de la batterie de l'iPhone X: étape 10, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 10, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 10, image 3 de 3
    • Faites glisser le médiator le long du coin inférieur gauche de l'iPhone, ce qui va trancher l'adhésif qui maintient l'écran en place.
    • N'insérez pas le médiator de plus de 3 mm, vous risqueriez d'endommager des composants internes.
  11. Remplacement de la batterie de l'iPhone X, Informations écran iPhone X: étape 11, image 1 de 1
    • Il y a des nappes très fragiles sur le côté droit de votre iPhone. N'y insérez pas le médiator ! Vous risqueriez de les endommager.
    Wouldn’t it be better to put this part BEFORE the step where you have to pry open the phone?
    Jan D. Höllwarth - Réponse
  12. Remplacement de la batterie de l'iPhone X: étape 12, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 12, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 12, image 3 de 3
    • Ré-insérez votre médiator dans le bord inférieur de l'iPhone, et faites-le glisser jusqu'au côté droit pour continuer à séparer l'adhésif.
    • N'insérez pas votre outil de plus de 3 mm, vous endommageriez les nappes de l'écran.
    If you have flat feeler gauges (for adjusting engine valve tappet clearance, ignition points … old school) the .003” thick gauge goes right in. Work your way up in thickness until you can get the pic or supplied pry tool in. Don’t insert metal feeler gauge in too far, just enough to hold crack open. I didn’t need to use the suction cup. I used a hot/cold gel pack heated in microwave to heat edges to soften glue a bit. Made sure it wasn’t so hot I couldn’t stand it on my skin.
  13. Remplacement de la batterie de l'iPhone X: étape 13, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 13, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 13, image 3 de 3
    • Le bord supérieur de l'écran est retenu par de la colle et des clips.
    • Glissez le médiator sous le coin supérieur de l'écran tout en faisant délicatement jouer l'écran vers le bas, en direction du port Lightning.
    • Les clips peuvent se casser si vous forcez trop. Progressez avec prudence et restez patient.
    • N'insérez pas votre outil de plus de 3 mm. Vous risqueriez d'endommager la rangée des capteurs du panneau frontal.
    • Glissez le médiator sous le côté opposé pour faire céder l'adhésif restant.
    These are the best instructions I’ve ever read for anything.! Thank you!
    Peter Andrew - Réponse
  14. Remplacement de la batterie de l'iPhone X: étape 14, image 1 de 1
    • Tirez sur la petite bosse de la ventouse pour la décoller du panneau frontal.
  15. Remplacement de la batterie de l'iPhone X: étape 15, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 15, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 15, image 3 de 3
    • Ouvrez l'iPhone en tournant l'écran depuis le côté gauche, comme s'il s'agissait de la couverture au dos d'un livre.
    • N'essayez pas encore d'enlever complètement l'écran, car plusieurs nappes fragiles le relient toujours à la carte mère de l'iPhone.
    • Comme sur la photo, assurez-vous que le châssis se détache avec l'écran et ne reste pas coincé dans l'appareil.
    • Appuyez l'écran contre un objet pour le maintenir à la verticale pendant que vous travaillez sur le téléphone.
    • Lors du remontage, posez l'écran iPhone X à sa place, alignez les clips le long du bord supérieur. Puis appuyez délicatement sur le bord supérieur avant de refermer le reste de l'écran. S'il ne s'enclenche pas facilement, vérifiez l'état des clips sur le pourtour de l'écran et vérifiez qu'ils ne sont pas déformés.
    My phone came apart in a different way and looks not right the little box at the top of the display as actually bolted to the top of the frame body I think something went really wrong when I opened it.
    Mike Kostersitz - Réponse
    It opens like a book but be careful not to open it all the way — only as far as shown in the photo. Otherwise it will strain the thin cable that connects the sensor module and then no more FaceID for you (or, as it turns out me). This could have been made more explicit in the instructions.
    Richard Tucker - Réponse
    It opens like a book but be careful not to open it all the way  … the small stainless steel tabs that hold the screen around the metal frame, that are on the bend place (right side of the phone)… are tend to bend, you can straighten them back to 90 deg. but the plastic base that they are on? very fragile- watch out not to break the plastic bezel … it may come apart of the glass.
    dabur872 - Réponse
    Advice for re-assembly: Before closing up the phone with the seal, check if phone is powering up again and speaker, mic and sensors are still working. If done this check even before installing the board connector bracket in Step 13.
    Alexander Nowak - Réponse
  16. Remplacement de la batterie de l'iPhone X, Écran complet: étape 16, image 1 de 1
    Magnetic Project Mat
    $19.95
    • Dévissez cinq vis Y000 fixant le cache du connecteur de la carte mère, des dimensions suivantes :
    • Trois vis de 1,1 mm
    • Une vis de 3,1 mm
    • Une vis de 3,7 mm
    • Tout au long de cette réparation, veillez à bien organiser vos vis et à revisser chacune exactement là où elle était, afin d'éviter d'endommager votre iPhone.
    One thing I found helpful for replacing the screws was to use only the 000screwdriver tip, without the handle. This way, the tip isn’t magnetized and the screw doesn’t tend to ‘roll’ off the screwdriver tip (the screw has almost no mass, so the head (largest surface) is pulled around to the side of the screwdriver tip when magnetized).
    Rich May 23, 2020
    ungodly - Réponse
    My 3.1mm screw had a stripped head, could not remove it. (Factory defect, this iPhone was never opened)
    So I had to give up removing the display assembly, and jumped directly to battery replacement, Step 20.
    That was tricky as I had to keep the display at 90º with a risk of breaking display connectors, but hopefully the replacement went well.
    I would not recommend to do this but to follow the guide, but, in case someone encounters a similar issue, that could help!
    vingu - Réponse
    My 1.1mm screw had a stripped head. Used a 3mm steel drill to cut the head off (just 1 mm deep haha) so i could remove the bracket.
    Renout - Réponse
    Be careful on reassembly. Keep the screen supported and not moving. I had difficulty getting the screws in and ended up ruining the screen connectivity at the back of the screen where the ribbon cables go in near the center. I was trying to hand hold the screen and it ended up moving around too much.
    SETH GREEN - Réponse
    To keep track of the screws, I copy the photos showing their places, then arrange these photos on document in Pages, print it. Next I apply two sided sticky tape (the roll-on type). So all screws have their corresponding places …
    Max Glanzmann - Réponse
  17. Remplacement de la batterie de l'iPhone X: étape 17, image 1 de 1
    • Retirez le cache.
    • Il se peut que le cache soit légèrement collé. Soulevez-le délicatement mais fermement pour le décoller.
    • C'est le moment idéal lors du remontage pour allumer votre iPhone et en tester toutes les fonctions avant de le refermer hermétiquement. Veillez à rééteindre complètement votre iPhone avant de continuer votre ouvrage.
    I tested it, then proceeded to close up the device without the bracket. Do I need to reopen and install? All connections are good?
    monastra7 - Réponse
    The bracket helps those many connectors underneath maintain good contact. Probably in the short term nothing bad will happen, but I’d hang onto the bracket and reinstall it when convenient.
    Jeff Suovanen -
    Agree with Jeff
    cgtyoder -
    I tested all imaginable functionality on the new OLED screen. Taptics are fine. Then, I noticed that the battery wasn't charging. Any ideas as to what could have gone wrong?
    Monica - Réponse
    for me, the replacement battery was completely dead, small panic when the power-on button was pressed, but quickly realised that this was the situation, and now watching the phone take a power cycle.
    James Stanbridge - Réponse
    Before clicking the screen assembly back, I tried to test the iPhone by pushing the start button, but nothing happened. After taking off the bracket, reseating the plugs I tried again - nothing happened! Then I plugged in the charging cable connected with the iMac, and it started immediately. So if the phone does not start using the startup button, it might just be a glitch when reconnecting the battery.
  18. Remplacement de la batterie de l'iPhone X: étape 18, image 1 de 2 Remplacement de la batterie de l'iPhone X: étape 18, image 2 de 2
    • Faites levier avec la pointe d'une spatule (spudger) ou un ongle propre pour débrancher le connecteur de la batterie de sa prise sur la carte mère.
    • Essayez de n'endommager aucun des joints en silicone noir qui entourent les connecteurs de la carte. Ces joints sont une protection supplémentaire contre les intrusions de liquide et de poussière.
    • Repliez et écartez légèrement le connecteur de la carte mère pour éviter qu'il ne rentre accidentellement en contact avec la prise et alimente le téléphone pendant que vous effectuez la réparation.
    cosa può succedere se non si disconnette la scheda logica'?
    luca.valli - Réponse
    note: be careful not to crush or puncture your battery at this step!! I gave mine a minor dent, which I hope wont be a problem.. but something to keep in mind for fxlks in the future!
    Noal Balint - Réponse
    Thanks, already did it)
    Stephen Hedrick -
  19. Remplacement de la batterie de l'iPhone X: étape 19, image 1 de 2 Remplacement de la batterie de l'iPhone X: étape 19, image 2 de 2
    • Avec la pointe d'une spatule ou un ongle, déconnectez l'ensemble capteur du panneau frontal.
  20. Remplacement de la batterie de l'iPhone X: étape 20, image 1 de 2 Remplacement de la batterie de l'iPhone X: étape 20, image 2 de 2
    • Servez-vous de la pointe d'une spatule ou d'un ongle pour déconnecter le connecteur de la nappe du panneau OLED.
    • Les connecteurs à pression comme celui-ci se reconnectent ainsi : alignez-les soigneusement et appuyez d'un côté puis de l'autre pour les enclencher. N'appuyez pas au milieu. Si un connecteur est mal aligné, les broches pourraient se déformer et causer des dommages irrévocables.
    Snap ‘em in like little Legos.
    Ray Johnson - Réponse
    Maybe the manual should flip step 17 and 18 (as the digitizer cable from 18, is in the way of the OLED cable of step 17) ?
    Renout - Réponse
  21. Remplacement de la batterie de l'iPhone X: étape 21, image 1 de 2 Remplacement de la batterie de l'iPhone X: étape 21, image 2 de 2
    • Soulevez le connecteur de la nappe de la vitre tactile avec la pointe d'une spatule pour le débrancher de sa prise.
    • L'espace restreint autour de ce connecteur en complique la reconnexion. Prenez votre temps et alignez-le correctement, puis appuyez soigneusement avec le bout du doigt – d'un côté, puis de l'autre. Vous devriez entendre un clic quand il s'enclenche.
    • Si jamais une partie de votre écran ne réagit plus quand vous avez fini la réparation, déconnectez la batterie, puis réenclenchez ce connecteur, en veillant à ce qu'il fasse bien clic et qu'il n'y ait ni poussières ni saletés sur la prise.
    This was probably the hardest part other than trying to get the screen off with the crappy suction cups. I re-installed the bracket only the find out that the touch screen would not respond to touch. Had to remove the five screws, remove the bracket and reseat the recessed screen connector. Reseating the bracket took another 10+ minutes. I carefully used the angled forceps to grab the cable and align the connector being careful not to damage the cable.
    Once you have the connector seated, I would reconnect the battery, power on the phone, and check the touch screen response before re-installing the bracket (step 13).
    Yeah, this was probably the trickiest part of the reassembly. The power connector cable kept getting in the way so I moved it carefully but fully out of the way. Then it was a matter of fiddling around with it a bit and being careful not to force it on.
    Jeffrey Hoy -
    I was positive that I had messed something up, I had powered up the phone to test three different times and everything seemed find except there was no touch at all. On my fourth attempt, I carefully examined everything for dust and debris (blowing gently), and I did notice that a corner of the connector (more like part of the ribbon) was bent slightly, and I straightened it. I don't know if it was the ribbon or some tiny debris, but after reseating a fourth time, it worked.
    Pol Llovet - Réponse
    Very important part of the tutorial. Be careful and patience! In my case the screen and camera didn't respond after assemble, so I tried again to reconnect the connector like tutorial said and it worked well. Now my iPhone feel like a new one 💪🏼
    Efrain Maestre - Réponse
  22. Remplacement de la batterie de l'iPhone X: étape 22, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 22, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 22, image 3 de 3
    • La nappe de l'ensemble capteur du panneau frontal adhère légèrement en dessous.
    • Soulevez délicatement la nappe jusqu'à ce que l'adhésif cède.
    Do this sensor affect face id?
    bonglkv - Réponse
    It is part of the face id part so yes. This is the ear piece too so if the ribbon tears there is a chance the ear piece will stop working as well.
    Stephen Patterson - Réponse
    Be super careful handling this ribbon particularly. I did a battery install and, when I was done, I had a phone with a new battery and no Face ID. That’s a $300 Apple repair, and no 3rd party shop will touch it. I believe the ribbon lays vertically (i.e., perpendicular to the “floor” of the phone, against the side edge of the battery. During the re-install, I must have forced the ribbon into position after seating the connector, causing fatal flexing of the ribbon. (Don’t know this for sure, but I see another comment saying that this cable is part of Face ID.) Anyway, bottom line: BE CAREFUL REMOVING AND REINSTALLING THIS RIBBON!
    Jonathan Pines - Réponse
    My flex cable was more than lightly adhered in place. I needed to use a guitar pic or similar to help encourage adhesive to separate. I wouldn’t pull too hard like shown in pictures unless you had just the right grip on the ribbon cable so as to avoid damaging flex cable. See note above (5/31/20)
    Bizarre — it turns out my whole front panel sensor assembly came entire off of the front screen and is stuck to the logic board.
    Karl Jarvis - Réponse
    I also found the glue quite recluctant to release so I applied a second or two of heat using the wife's hair dryer which softened it and the cable lifted much easier then. Be careful not to apply too much heat though which could then impact other internal components.
    LosBenitos - Réponse
    Cho ít cồn 90° vào để mềm keo dễ tháo
    huuhaukimngan - Réponse
    my iphone x doesn't have a front panel sensor? in fact, it looks completely different than the picture???
    Kenneth McLeod - Réponse
    @kennethmcleod, most likely you've separated the screen frame from the screen itself. We see this most commonly when people neglect to remove the pentalobe screws next to the charging port. Usually the cure is to take out those screws, then repeat the screen removal process on the frame that's still attached to the phone.
    Jerry Wheeler -
    You don't need to disconnect the front sensor to change the screen. Just leave it connected and remove from the screen side.
    Anthony Boshell - Réponse
    I have damaged the front panel sensor assembly flex cable. Does it carry multiple channels of info or is it just one solid piece that can be soldered back together? If not, will the phone still work except Face ID?
    Bodger Rabbit - Réponse
  23. Remplacement de la batterie de l'iPhone X: étape 23, image 1 de 1
    I tried this and broke the cable can it still repair
    Alexis Rodriguez - Réponse
    At this point I would have found it easier to remove the glue from the edges than later on when I was reassembling it. I bought the kit that had the replacement glue in it.
    Grant - Réponse
    Excellent guide! Would love to have a link to moving the sensor assembly from the old display to the new here.
    Nicole - Réponse
    CAUTION:
    Removing the Taptic Engine or Speaker in next step is optional and the guide continues as this was per se needed.
    Unnecessary work and also If you remove the speaker you lose the adhesive gasket and this is not included in the scope of delivery of the "Battery replacement" offering.
    So do not remove and avoid losing waterproofing.
    Julian Gonzalez - Réponse
    Just to confirm the face id is not affected when replacing the earpiece assembly? Am I correct
    mubeen.2011@hotmail.co.uk - Réponse
    Sorry for the late response, but you are NOT correct. Replacing the earpiece speaker assembly will result in the loss of Face ID functionality. That's the whole assembly, including the speaker, dot projector and flood illuminator. If you unsolder the speaker from the assembly, that can be replaced by itself without losing Face ID, but any other part will cause it to quit working.
    Jerry Wheeler -
  24. Remplacement de la batterie de l'iPhone X, Haut-parleur inférieur: étape 24, image 1 de 2 Remplacement de la batterie de l'iPhone X, Haut-parleur inférieur: étape 24, image 2 de 2
    • Faites attention à ne pas toucher les trois lignes de contacts proches du bas de l'iPhone (encadrées en rouge).
    • Retirez les sept vis qui fixent le cache sur le Taptic Engine et le haut-parleur :
    • Deux vis Y000 de 1,9 mm
    • Une vis Y000 de 1,2 mm
    • Une vis Y000 de 1,6 mm
    • Une vis cruciforme de 2,4 mm
    • Une vis cruciforme de 1,7 mm
    • Une vis cruciforme de 1,5 mm
    For battery replacement:
    It is not necessary to remove Taptic Engine and speaker to replace a battery. Go straight to the step #33
    Additional video: https://youtu.be/2GfBOlJEW10
    Alexander - Réponse
    I wish I seen this before I did all that! Thank you for that information. Next time I do something like this. I'm gonna pay more attention to the comments.
    Eric Marino -
    Removing the Taptic Engine and speaker greatly improves your chances of getting the battery adhesive strips out intact. If those break, you’ll have a much tougher time.
    Jeff Suovanen -
    Boy, I tried to skip removing these items but was unable to get the glue strips out with them in place, not much to grab and tabs were kind of stuck to a seam in the battery, and hard to tell the difference between the seam and the strip tabs. For me I had to remove these items to get this done.
    marshallburchard -
    I stopped removing things after getting the display side off. There were 3 screws stripped on the speaker cover which wouldn't come out so I punted. Just pried the battery out with a smudger tool and some patience, starting at the top and working towards the bottom. New battery is in and working fine.
    Andy Price - Réponse
    The 2.4mm screw identified as “green” needs a Y000 screwdriver
    seb6po - Réponse
    Thanks for not removing the following steps. this made me break the connector for the bottom speakers >:(
    Andrew Romano - Réponse
    The color codes are missing from my display — only on this step.
    nat2 - Réponse
    The screws color and quantities in list don’t match the schematic ! I wish i had a magnetic screw mat before starting, because not only i removed the Taptic Engine and speaker unnecessarily, but i also lost a screw ?
    fb.mailing.lists - Réponse
    For first timer, dont think its possible to skip these steps and remove battery. It’s hard to remove the glue
    Wex - Réponse
    Does anyone know the purpose of this bracket "with grounding pads"? What would be the possible side effects if it was damaged or not connected properly during reassembly?
    Anne Aunyme - Réponse
    Hello, in my case the grounding pads are damaged. I've had problems since EMC. When I try to charge wirelessly, the iphone starts wild button presses (Gosting).
    Does anyone know, where I can get new grounding pads (with or without bracket)?
    Ulrich Höfelmeyer -
    I had to remove the tactic and speaker could not get the glue strips out so glad the steps to do so were in this guide.
    P Bond - Réponse
    Sure would like to know WHY the warning "Be careful not to touch the three rows of grounding pads..." What would or could happen if I did touch them??
    Chad Gagnon - Réponse
    Removing the battery strips is a major PITA, just skip this step and everything onwards, remove the one strip on the top part of the battery (according to step 33) and for the bottom part of the battery, pry it off with a plastic spudger.
    Yes, this is not the elegant solution, but the quickest and easiest one. This method is better, as you don't want to keep the old battery anyway, so why bother. (You must not puncture the battery though! But as long as you're only working with a plastic tool and are careful, nothing can happen from my experience.)
    speaker gasket - Réponse
    Remove the adhesive from the top part of the battery, squirt some ipa into the bottom part and it will come off easily, then skip to 38.
    Kim Boulton - Réponse
  25. Remplacement de la batterie de l'iPhone X: étape 25, image 1 de 2 Remplacement de la batterie de l'iPhone X: étape 25, image 2 de 2
    • Soulevez le cache par le bord le plus proche de la batterie. N'essayez pas encore de le retirer complètement, car il est toujours connecté à une petite nappe.
    Ulrich Höfelmeyer - Réponse
  26. Remplacement de la batterie de l'iPhone X: étape 26, image 1 de 2 Remplacement de la batterie de l'iPhone X: étape 26, image 2 de 2
    • Repliez le cache et utilisez la pointe d'une spatule (spudger) pour soulever et déconnecter la nappe qui se trouve en dessous.
  27. Remplacement de la batterie de l'iPhone X: étape 27, image 1 de 1
    • Ôtez le cache.
    My bracket was in two pieces.
    Jim Steward - Réponse
  28. Remplacement de la batterie de l'iPhone X: étape 28, image 1 de 2 Remplacement de la batterie de l'iPhone X: étape 28, image 2 de 2
    • Dévissez la vis Y000 de 2,1 mm qui fixe le cache du connecteur du haut-parleur.
    L'unique vis non?
    Easy Repair - Réponse
    Effectivement ;-) Merci pour les bons yeux et la remarque !
    Claire Miesch -
  29. Remplacement de la batterie de l'iPhone X: étape 29, image 1 de 1
    • Retirez le cache du connecteur du haut-parleur.
  30. Remplacement de la batterie de l'iPhone X: étape 30, image 1 de 2 Remplacement de la batterie de l'iPhone X: étape 30, image 2 de 2
    • Avec la pointe de la spatule, soulevez et débranchez le connecteur du haut-parleur.
    As mentioned in a comment by timblake2112 (see step 29), this step is not necessary and can be skipped skipped. I would advise you to do so, as removing your speaker is guaranteed to ruin your gasket and rubber seal. This will result in loss of water resistancy of your iPhone and could potentially harm the sound quality of your speaker.
    Try removing the Taptic Engine without removing the speaker. It might still be possible removing the battery adhesive strips and your speaker will stay in its original condition.
  31. Remplacement de la batterie de l'iPhone X: étape 31, image 1 de 2 Remplacement de la batterie de l'iPhone X: étape 31, image 2 de 2
    • Quand vous soulevez le haut-parleur, veillez à ne pas endommager la nappe que vous venez de déconnecter. Si nécessaire, repliez-la de côté pour retirer commodément le haut-parleur.
    • Insérez une spatule sous le bord supérieur du haut-parleur dans le coin de la coque de l'iPhone.
    • Faites délicatement levier pour soulever le bord supérieur du haut-parleur.
    • Au moment de remonter le haut-parleur, vérifiez la position de la nappe et veillez à ce qu'elle ne reste pas coincée sous le haut-parleur.
  32. Remplacement de la batterie de l'iPhone X: étape 32, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 32, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 32, image 3 de 3
    • Saisissez le haut-parleur par les bords latéraux et faites-le osciller d'un côté à l'autre pour faire céder l'adhésif qui le fixe au bord inférieur de l'iPhone.
    • Écartez le haut-parleur du bord inférieur de l'iPhone jusqu'à ce que le joint adhésif se décolle.
  33. Remplacement de la batterie de l'iPhone X: étape 33, image 1 de 2 Remplacement de la batterie de l'iPhone X: étape 33, image 2 de 2
    • Retirez le haut-parleur.
    • Le joint adhésif du haut-parleur n'est pas réutilisable. Nettoyez tous les résidus d'adhésif avec une pincette.
    • Lors du remontage, remplacez le joint adhésif pour une protection plus efficace contre l'intrusion d'eau et de poussières. Nettoyez la surface avec un peu d'alcool isopropylique et un chiffon non pelucheux ou un filtre à café pour que le joint adhère correctement. Collez un nouveau joint sur le haut-parleur, puis posez le haut-parleur.
    You don’t need to remove the speaker and ruin its gasket. You can wiggle and slide the taptic engine out without removing the speaker. I’ve done this twice on rear shell replacement jobs.
    timblake2112 - Réponse
    Maybe I'm a bit daft, but where's the instruction just how to line up the speaker gasket when replacing? I only have one so I'd like to avoid wrecking it. And I completely cleaned off the old one in order to do a good job of things. Why no simple instruction from part supply link?
    MrRoundel - Réponse
  34. Remplacement de la batterie de l'iPhone X, Taptic Engine: étape 34, image 1 de 2 Remplacement de la batterie de l'iPhone X, Taptic Engine: étape 34, image 2 de 2
    • Dévissez la vis cruciforme de 2,3 mm qui fixe le Taptic Engine.
  35. Remplacement de la batterie de l'iPhone X: étape 35, image 1 de 2 Remplacement de la batterie de l'iPhone X: étape 35, image 2 de 2
    • Soulevez la nappe du Taptic Engine tout droit vers le haut avec une spatule (spudger) pour la débrancher.
  36. Remplacement de la batterie de l'iPhone X: étape 36, image 1 de 1
    • Ôtez le Taptic Engine.
  37. Remplacement de la batterie de l'iPhone X, Batterie: étape 37, image 1 de 1
    • La batterie de l'iPhone X est fixée à la coque arrière par quatre bandes adhésives élastiques de retrait – une sur la cellule supérieure et trois sur l'inférieure.
    • Chaque bande adhésive se finit par une languette d'extraction noire. Celle-ci est légèrement collée sur le côté de la batterie.
  38. Remplacement de la batterie de l'iPhone X: étape 38, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 38, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 38, image 3 de 3
    • Décollez la première languette adhésive de la partie inférieure de la batterie.
    • Au milieu de chaque languette se trouve un petit trou, insérez-y un outil si vous avez du mal à saisir la languette.
    • Ne percez pas la batterie avec un outil pointu. Une batterie perforée risque de laisser s'échapper des produits chimiques dangereux ou de prendre feu.
    hole breaks instantly on pulling. adhesive tab does not release from side of battery
    Dominick garton - Réponse
    I had a lot of trouble with this. Only two came out properly and the others snapped off. I heated up the back of the phone with a hair dryer then used the flat end of the spudger to slowly pry it off right to left, bottom to top.
    Grant - Réponse
    just pry it off, why bother
  39. Remplacement de la batterie de l'iPhone X: étape 39, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 39, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 39, image 3 de 3
    • Répétez l'étape suivante pour décoller les deux bandes adhésives restantes du bord inférieur de la batterie.
    • Veillez à ne pas endommager le connecteur de la nappe du haut-parleur, qui se trouve juste en dessous de la bande adhésive centrale.
  40. Remplacement de la batterie de l'iPhone X: étape 40, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 40, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 40, image 3 de 3
    • Au cours des étapes suivantes, vous tirerez sur chaque languette pour étirer doucement la bande adhésive sous la batterie. Quand elle s'étire, cette bande adhésive élastique spéciale perd son adhérence et se décolle, ce qui vous permettra de soulever aisément la batterie.
    • Si une des bandes se déchire, ne paniquez pas ! Elles ne fonctionnent pas toujours comme elles le devraient. Allez voir quelques étapes plus loin comment procéder avec les bandes déchirées.
    • Pour augmenter vos chances de succès :
    • N'appuyez pas sur la batterie. Tenez fermement votre iPhone par les côtés.
    • Veillez à ce que les bandes restent le plus horizontales possible et ne fassent pas de plis quand vous tirez dessus.
    • Tirez très lentement pour donner aux bandes le temps de s'étirer et de se décoller. Il vous faut environ 15 à 30 secondes pour chaque bande.
    • Tirez de façon à ce que la bande ne reste pas accrochée le long du bord inférieur de la batterie.
    • Si vous déchirez une bande sous la batterie et n'arrivez pas à l'enlever, continuez avec les autre bandes, puis référez-vous aux instructions spécifiques plus bas.
  41. Remplacement de la batterie de l'iPhone X: étape 41, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 41, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 41, image 3 de 3
    • Saisissez la languette adhésive à gauche ou à droite de la batterie, puis tirez dessus, depuis la batterie vers le bas de l'iPhone.
    • Tirez régulièrement, en exerçant une tension constante sur la bande jusqu'à ce qu'elle glisse hors de son emplacement entre la batterie et la coque arrière.
    • La bande va s'étirer jusqu'à atteindre plusieurs fois sa longueur de départ. Si nécessaire, ressaisissez la bande du côté de la batterie et continuez à tirer.
    • Si les languettes adhésives de la batterie se déchirent pendant que vous les retirez, servez-vous de vos doigts ou d'une pincette arrondie pour récupérer ce qui reste de la bande et continuer à tirer.
    • Si vous déchirez une bande sous la batterie et n'arrivez pas à la récupérer, essayez de décoller les autres bandes, puis référez-vous aux instructions spécifiques plus bas.
    I found it easier to grab the end of the adhesive strip sideways with narrow tweezers, "twirl " the tweezers to wrap the strip around them a few times, then gently pull the strip with the tweezers.
    punkinann - Réponse
  42. Remplacement de la batterie de l'iPhone X: étape 42, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 42, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 42, image 3 de 3
    • Répétez l'étape précédente pour retirer la bande de l'autre côté et gardez celle du milieu pour la fin.
  43. Remplacement de la batterie de l'iPhone X: étape 43, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 43, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 43, image 3 de 3
    • Retirez la bande du milieu en veillant à ce qu'elle ne reste pas accrochée à la nappe du haut-parleur.
  44. Remplacement de la batterie de l'iPhone X: étape 44, image 1 de 2 Remplacement de la batterie de l'iPhone X: étape 44, image 2 de 2
    • La dernière languette d'extraction est juste à côté du module Face ID. Si vous l'abîmez, seul Apple sera capable de le réparer, donc faites bien attention.
    • Décollez et soulevez la languette d'extraction de la dernière bande adhésive, qui se trouve en haut de la cellule de batterie supérieure.
    surtout ne pas passer avec la spatule par le bas, vous risqueriez d arracher la nappe du volume et du nfc,
    Ludovic Klein - Réponse
  45. Remplacement de la batterie de l'iPhone X: étape 45, image 1 de 3 Remplacement de la batterie de l'iPhone X: étape 45, image 2 de 3 Remplacement de la batterie de l'iPhone X: étape 45, image 3 de 3
    • Tirez et ôtez la dernière bande adhésive.
    • Cette bande risque d'éjecter la batterie pendant que vous la décollez de l'iPhone, donc posez votre main sur la batterie pour la maintenir en place. Cependant n'appuyez pas dessus. La pression supplémentaire risque de déchirer la bande adhésive sous la batterie.
    • Si vous avez réussi à retirer les quatre bandes adhésives, sautez l'étape suivante.
    • Si une (ou plusieurs) des bandes adhésives s'est cassée sous la batterie et ne peut pas être récupérée, appliquez quelques gouttes d'alcool isopropylique à forte concentration (supérieure à 90 %) sous le bord de la batterie, dans la zone de la ou des bandes adhésives cassées.
    • Attendez une minute que la solution alcoolisée ramollisse la bande adhésive. Utilisez le bout plat d'une spatule antistatique pour faire doucement levier sur la batterie.
    • Ne forcez pas pour faire levier et sortir la batterie. Si nécessaire, appliquez quelques gouttes d'alcool supplémentaires pour continuer à ramollir l'adhésif. Ne jamais déformer ou percer la batterie avec votre outil de levier.
    • Faites attention à n'endommager ni les nappes ni la bobine de recharge sans fil sous la batterie.
    • Pour des méthodes alternatives pour décoller la batterie, continuez à l'étape suivante ci-dessous.
  46. Remplacement de la batterie de l'iPhone X, Méthode alternative pour décoller la batterie de la coque: étape 46, image 1 de 2 Remplacement de la batterie de l'iPhone X, Méthode alternative pour décoller la batterie de la coque: étape 46, image 2 de 2
    • Si une des bandes adhésives s'est déchirée et que la batterie reste coincée dans la coque arrière, préparez un iOpener ou servez-vous d'un sèche-cheveux pour faire chauffer la coque arrière derrière la batterie.
    • Chauffez l'iPhone jusqu'à ce que la coque arrière soit légèrement trop chaude pour un toucher confortable. Ne le faites pas trop chauffer, la batterie risquerait de prendre feu.
    • Retournez l'iPhone et faites glisser une ficelle solide (du fil dentaire ou une fine corde de guitare par exemple) sous la batterie.
    • Enroulez un chiffon autour des bouts de la corde (ou portez des gants) pour protéger vos doigts.
    • Tirez la ficelle d'un côté puis de l'autre, dans un mouvement de scie, et ce tout le long de la batterie pour faire céder l'adhésif. Cela risque de prendre du temps, car l'adhésif cède lentement. Soyez patient et vous en viendrez à bout. Ne déformez ni endommagez la batterie.
    • Si vous choisissez d'utiliser des outils à levier pour soulever la batterie hors de l'iPhone, faites extrêmement attention, vous risquez d'endommager les nappes ou la bobine de recharge sans fil, qui se trouvent juste au-dessous de la batterie.
    if you use a guitar string, remember NOT to use a METALLIC guitar string.
    Ross King - Réponse
    flexible plastic rules with alcohol work too
    Wex - Réponse
    I can confirm that IPA (Iso Propyl Alcohol) and, in my case, the plastic plectra in any iFixit kit worked a treat.
    P Bond -
  47. Remplacement de la batterie de l'iPhone X: étape 47, image 1 de 1
    • Tenez la batterie par le bas et retirez-la de l'iPhone.
    • S'il reste de l'alcool dans le téléphone, essuyez-le soigneusement ou laissez-le sécher à l'air libre avant d'insérer votre nouvelle batterie.
    • Remontez le Taptic Engine et le haut-parleur avant d'installer une nouvelle batterie. Cela aide à aligner correctement la batterie quand on la monte.
    • Avant de coller la batterie de remplacement, rebranchez temporairement le connecteur de la batterie à sa prise sur la carte mère. Cela permet de s'assurer que la batterie est correctement alignée dans son compartiment.
    • Posez la batterie, débranchez-la et continuez à remonter votre appareil.
    • Si votre nouvelle batterie n'est pas fournie avec de l'adhésif, consultez ce tutoriel pour remplacer les bandes adhésives de votre batterie.
    • Forcez le redémarrage après avoir fini de remonter votre iPhone. Cela pourra vous éviter des problèmes et en simplifier le diagnostic.
    When reinstalling the battery, the Taptic Engine does serve as a useful way to orient the battery, but it should also be noted that if you push right up against that as you install the battery (as I did) and don’t pay any attention to power connector (shown in step 14), there is a risk that the connector from the battery will not line exactly with the connector port on the board. Mine was only off a mm so I had to get a little creative to try to get it to stretch to reach and connect to the port on the board. Just keep that in mind as you place the battery (with adhesive) down.
    Jesse Bolane - Réponse
    Connect the battery first then put it in place. Other way it is hard to adjust power connector.
    Alexander - Réponse
    I would also HIGHLY suggest re-installing the speaker as well before installing the battery - it was a very tight squeeze as the bottom-right of the battery was snug against the speaker when I tried to get that back in.
    cgtyoder - Réponse
Comparez votre nouvelle pièce de rechange à la pièce d'origine, vous devrez peut-être transférer les composants restants ou enlever les films adhésif au dos de la nouvelle pièce avant de l'installer.
Pour réassembler votre appareil, suivez les étapes ci-dessus dans l'ordre inverse.
Apportez vos déchets électroniques à un point de collecte certifié.
La réparation iPhone X ne s'est pas déroulée comme prévu ? Consultez notre forum de réponses pour obtenir de l'aide au diagnostic. Notre communauté iFixit sera à même de pouvoir vous conseiller sur ce changement d'écran iPhone X si vous avez des questions ou des doutes.
415 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Jeff Suovanen
Membre depuis le 08/06/13
439 280 Réputation
259 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 413 tutoriels rédigés
57 commentaires
In the store it says the iSlack is only for iPhone 5 and 6. In this review the iSlack is used (without tray). Does that mean it can be used on the iPhone X as well?
Ronald van der Meer - Réponse
@rvdm The little bracket in the middle of the iSclack is sized for iPhone 5, but that bracket is optional and very easy to detach. At that point you have a really great general-purpose suction tool that works for all kinds of devices (even bigger ones like tablets). I’ll see about updating the description on the store page to reflect that fact. ;)
Jeff Suovanen -
Have you all ever had a problem of the phone staying stuck on a percentage and takes so long to charge plz let me know because I just got my iPhone X and it take so long to charge and I got it brand new from AT&T
Cristan Montes - Réponse
Esta solucionado el tema del Chip Texas instrument para baterias no reemplazadas en Apple, gracias.
FELIX MARQUEZ - Réponse
¿A qué te refieres con eso?
Tomas -
C’è un errore di traduzione al passo 33 BATTERIA , iphone X diventa iphone 8.
Marco
Marco Pautasso - Réponse
Ciao Marco! Hai occhi di lince! Grazie per il commento. Ho corretto la traduzione. Commenti di questo tipo sono sempre benvenuti. Hai anche la possibilità di adattare direttamente la traduzione, cliccando sull’icona “Traduci”. Saluti, Claire
Claire Miesch -
Note that my replacement battery was completely dead when I installed it, so when I tested it, I thought perhaps something wasn’t hooked up right. After removing the bracket for the connectors and reattaching the battery connector I tried again. Since that failed, I plugged the phone in. I got a “no charge” battery icon. After a few minutes I removed the phone from the charger. The phone stayed on with the “plug in the phone” icon, so I knew everything was put back together correctly.
Jon12 - Réponse
Critical Note! When installing the new battery make sure the connector lines up. The instructions mention having the speaker and taptic engine in place so I focused on squaring up with those. This was a mistake! Now my connector is 2mm too low and won’t line up. Not sure how I will fix this yet but hopefully I won't need to remove everything again.
Christopher Jones - Réponse
Where can I buy a genuine original iPhone X battery as amazon Walmart sells fake batteries
masrin - Réponse
You can not buy a genuine battery.
Alexander -
How to make out a genuine original battery from a fake one sold all over the globe?
masrin - Réponse
Super Set, auch toll das hier die Dichtung dabei ist. Akku lädt und zeit die %-Werte an. Beim nächsten Mal kauf Ichs gleich hier"! War jetzt schon die 2te Reparatur. Mittlerweile schaff ich das schon ca. 40 min ;)
Danke
Peter - Réponse
Aparecerá el porcentaje de la batería en el apartado de “salud”?
Gustavo González Martínez - Réponse
removing the components that are below the battery seems rather unnecessary to me, you could remove the battery without taking those out
Samuel Casas - Réponse
I had an issue with a swollen battery on a iphone X, the battery was pushing the display assembly and the phone couldn’t close properly. Replaced with new battery and all went fine. Great guide as always
Georgi Ivanov - Réponse
This battery already comes with battery health indicator or need to reprogram the battery ?
danial nabil - Réponse
Big thank you for introduction!
commaai - Réponse
It would be nice if this addressed the waterproof adhesive, mentioned in Step 6. Doesn’t pulling the phone apart make it no longer watertight?
Winston - Réponse
Instructions for replacing the adhesive seals are linked in the guide (Step 19). I wouldn’t count on your phone being waterproof after a repair, but a phone from 2017-2018 likely won’t be particularly water-resistant anymore, anyway. Those seals tend to degrade over time.
Jeff Suovanen -
Hi, I bought the battery from you and installed it exactly like your steps.
But after two days of use, a message appears to me that this battery is not original and its percentage cannot be read !!!
What to do now ???
Fahad Mohammad Fahad - Réponse
When changing the battery to a third party one, are there any notifications that appear such as “not a genuine battery” and does reprogramming the battery help prevent this.
Farjad Akram - Réponse
BE WARNED! THE IPHONE’S OUTSIDE IS VERY, VERY SHARP! I escaped with 4 cuts on my fingers.
AemVR - Réponse
I replaced two of these in one night. The first one worked great but the second’s OLED screen won’t come on. The phone is on because I can hear it charge when I plug it in, but for some reason the screen is dead.
Lucas - Réponse
If you’re buying the battery from iFixit I strongly suggest getting the full kit and not the battery-only option so that you get the glue and the gasket. Great guide, thank you!
Grant - Réponse
It is perfectly possible to do the replacement without removing anything other than the bracket and the battery connector.
This reduces the number of steps to about 10 and takes about 15 minutes.
Neil Roberts - Réponse
Awesome guide! I finished it, and now I have a fully working X
Just one thing: the video and the instructions differ on step 20, making the rest unnecessary according to the video guide. On the other hand, it may facilitate taking the glue off, especially for newbies.
Ed Oliver - Réponse
I don’t want to sound like “that guy,” but the cost of a battery replacement is only $69 at an Apple Store. This DIY solution, which can go t!ts up anywhere along the 43 steps, requires the purchase of parts that cost almost as much as just letting Apple do it. I love fixing/replacing/upgrading my hardware as much as the next guy, but this seems like a scenario where the majority of people would be better off visiting an Apple Store.
koelpien - Réponse
Except that authorized stores won’t replace a swollen battery, and neither will Apple. Otherwise yes, if the few hours extra and a few 10s of dollars is the additional price for a turnkey solution, most folks are better off having the work done for them.
Mike Hocker -
Was suffering from a hugely swollen battery so it made removing the adhesive pretty difficult (and I was being super careful since the battery had swollen so much). The “stretch and pull” with the adhesive was a no-go and I was hesitant to heat the phone. I ended up slowly pulling up on the battery at the top and gently working the adhesive away. It took some time, but worked out.
Great guide, as usual!
Patrick C - Réponse
Jeg har lige skiftet batteri på min iPhone X i starten kunne jeg kun oplade trådløst, men nu kan jeg slet ikke oplade Den reagerer slet ikke på noget mere den er helt død Hvad kan jeg gøre ???
enok - Réponse
The adhesive under the original battery broke. ALL TABS RIPPED APART! I have no floss nor metal guitar string. Help please. This is my only mobile phone. I need it 24/7.
vmm - Réponse
Commentary on swelled batteries: don’t tell Apple, they will mark your iPhone SerialNumber in their database as not repairable and you will never be able to get a battery replacement in the future (per Apple phone support, as we tried to get their swollen battery replaced by appointment). We are not happy campers, now I need to use up valuable time replacing the battery. At least replacing the battery is an option with the help of iFixit. (oh, and they won’t put in a new battery if I remove the old one either— although once the old one is removed the hardest part of the work is done)
Mike Hocker - Réponse
Wasn’t too bad, except some of the screws that need to be removed are tiny and I found out that my eyes are not the best anymore ?.
jabuka - Réponse
Many thanks for this great tutorial !! Just changed the battery of my 4 years old iPhone X, I’m very happy to have a fresh one inside !
Faabio - Réponse
Hello,
I have an iPhone X Model number MQAF2LZ/A bought in Perú and once I started removing the display I noticed it doesn’t open like in the pictures or video here. There is a connector behind the ear piece that connects to the main board and I can’t open it. I see if I force it I will break this connector. Have somebody worked with this model? and recommend where to buy a replacement display? The one I bought is for model number MQAF2LL/A (USA). (the ribbon cables look different)
John W - Réponse
Today I show you how to replace the battery of the Iphone X. We need one screwdriver, one suction cup, 1 iopener, 1 pair of tweezers, 1 plastic pry tool, and 1 spudger.  Remember to turn off the power. The replacement can cause the loss of water resistance. To replace the battery for iphone X, do the following steps. Step 1, use the screwdrive to remove the screws at the bottom. Use Iopener to soften the adhesive. Clip the suction cup onto the screen and use a pry tool to pry out the screen. Lift up the screen 90 degrees on the right. Take off the small screws holding the battery cable and the motherboard. Next, use the tweezers to lift up the metal bracket. Use a spudger to pry away the battery connector and 3 display connectors. Use tweezers to remove the battery stripe. Remove the old battery. Reverse the above steps to install the new battery.
Hội Nguyễn - Réponse
This takes me like 2 mins no tools required and I reused the adhesives also so less waste . I dont pull anything or use tools bar a tri star….. Should be updated . Soak in alcohol slightly leave for 2 mins remove battery , dry and replace using old adhesive (which is perfect) no cleaning ….Digithaiz
Sam Barton - Réponse
Jeez I dont mind even making you a guide for this as its mostly sit and wait for all of the 5 mins max this takes!
Porcentaje de la Condición de la batería funcionará bien?
Inksane BēLCK - Réponse
Misma pregunta.
Tomas -
Hallo,
ich habe mein iphone x display und batterie ausgetauscht, allerdings bekomme ich die fehlermeldung
Apple erfasst die Hardwarekennungen Ihres iPhones, um unsere Dienste zu identifizieren und zu aktivieren.
İch habe mein iphone x damals in der türkei gekauft und leider komme ich nach weiter woran kann das liegen ?
mst Ozyn - Réponse
Excellent guide! Took about1,5 - 2 hours too including trying to remove all of that black sticky stuff! :) Should have bought some isopropanol... Aligning and fixing the new sealing was a bit tricky! Really had to think for a while which layer of plastic to remove first...
No problem removing the adhesive under the battery which never has worked on older iphones! pehww.... :)
Thomas Lundström - Réponse
Worked great. Only putting the display adhesive on was difficult. I am thinking about fixing the broken display now, because it maked so much fun!
Mike Stanke - Réponse
Personnellement je n’ai pas démonté les haut parleur et le bas de l’iPhone … j’ai directement chauffé à l’arrière et décollé la batterie …. Plus rapide et moins dangereux pour le reste
Dark Stig - Réponse
I don't know if it's common knowledge, but I just flashed on what the first sign of my battery expanding was. I used an Otterbox Defender case on my iPhone X. 3-6 months before the battery made its expansion obvious, the volume buttons started not working well. I thought it was the Otterbox. But now that I've replaced the battery the volume buttons are working fine. Somehow the battery was distorting the physical interface between the phone buttons and the case buttons. By the time I noticed the battery inflating, it had pushed up the display screen away from its frame. Apparently the battery was getting rather dangerous for possible setting itself ablaze.
MrRoundel - Réponse
0% Remaining cómo solucionar ??
Ernesto Salazar - Réponse
I replaced my battery just fine but now my screen is wonky. I’m getting yellow and black lines and it’s not working properly. I reattached everything twice but still no luck. Any body have the same issues or a fix? My screen was perfect before changing out my battery.
Jeremy - Réponse
This battery has to be reprogrammed to work with the health condition battery?
Tomas - Réponse
Thanks so much - this is exactly what I needed :)
Molly Floyd - Réponse
Holala, mais quelle galère juste pour changer la batterie sur le X !
Thibault Cadet - Réponse
Absolut spitze. Danke
Lu66 - Réponse
Had my iPhone X battery replaced by Apple today; they replaced the speaker (no charge). They say that the speaker has to be replaced when the battery is replaced. They did not explain why.
LaoK - Réponse
Please how can I jump battery terminals to the motherboard terminals with only positive and negative with jumping wire
Ramstar - Réponse
Please how can I jump iPhone X battery terminals to the motherboard with only positive and negative terminals to get correct battery percentage?
Ramstar - Réponse
For a total novice with electronic repairs this was a little stressful at first, but once I got a proper start, (i.e. was able to separate the screen from the case) I was easily able to follow along and complete the battery repair.  Not everything went according to plan, for example when the adhesive tabs under the battery were not accessible enough to pull, but lift and scrap method worked well.
Would be helpful if there were instructions (for novices) of how to install the new battery, what order (if any) to reattach the connections, how to place and peel the new screen adhesive, and then how to reattach the screen.  Perhaps these are available, and I’ve missed them.
Brilliant tutorial and left buzzing with confidence after watching my iPhone switch on, respond to commands,  and start charging.  Thank you.
mac - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 147
7 derniers jours : 828
30 derniers jours : 3,669
Total : 840,685
