Introduction
Le remplacement du boîtier nécessite le retrait de presque tous les composants de votre MacBook Pro. Vous devrez également transférer votre ancien trackpad sur votre nouveau boîtier.
Retirez les 10 vis suivantes par lesquelles est fixé le boîtier inférieur du MacBook Pro 13" Unibody :
Sept vis Phillips 3 mm.
Trois vis Phillips 13,5 mm.
Soulevez légèrement le boîtier inférieur et poussez-le vers l'arrière de l'ordinateur afin de désengager les pattes de fixation.
In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur de la batterie pour le débrancher de la prise sur la carte mère.
How do you get that battery connector back on? Do you just press it in back in place after you're done?
yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
Avec une spatule (spudger), soulevez le connecteur du ventilateur de son emplacement pour le débrancher de sa prise sur la carte mère.
I just soldered it back on. . . I tried to clean the pads with braid first, but it didn't do much so I don't think that's necessary. I first supper-glued it in place with the pins on the pads and then I put a tiny dab of solder on each pin/pad. Plugged in the fan and i works!
Just the answer I was looking for Ron! Awesome work buddy!
i recommend not to use the spudger. you damage more than by unpluggin the plug by hand. just simply pull the cable close to the plug of the old fan softly upwards out. the plug than comes easily out. put the new fan in and push the new plug by hand in. it is much easier than using a spudger. i also started with a spudger but nearly broke the plug out, so i watched a youtube tutorial and learned about it…
Saisissez la languette en plastique fixée au dispositif de verrouillage du câble de données de l'écran et pivotez-la vers le côté DC-In (prise d'alimentation) de l'ordinateur.
Tirez le câble de données de l'écran tout droit hors de sa prise sur la carte mère, vers le côté DC-In de l'ordinateur.
Retirez les deux vis suivantes, attachant la fixation du câble de données de l'écran au boîtier supérieur :
Une vis cruciforme de 7 mm.
Une vis cruciforme de 5 mm.
Retirez la fixation du câble de données de l'écran du boîtier supérieur.
If you only want to replace the DC-in board, stop here and GOTO 17 (and DO NOT 4 and 6).
When the Logic board is loose, lift it up on the Harddrive end and shift slightly towards the HD, so that the USB connectors at the outside come free from under the case rim and the board can be lifted up a bit. Then there´s enough room to move the DC in board, pull the cable out with a pair of tweezers, wriggle it out from under the microphone cable and wriggle the new connector in. It can be pushed into the socket with tweezers or a small screwdriver. This worked perfect for me.
Be careful not to bend the logic board, but otherwise I think there´s much less risk of messing anything up with all the connectors and bits and pieces that need to be loosened and fastened.
Tirez la nappe de la caméra vers le lecteur optique pour la débrancher de la carte mère.
There is a small piece just below this connector which is just an adhesive block to keep the connector from coming out. It is easiest to peel it up first with a fingernail or spudger then remove the cable. Likewise reinsert the cable before reapplying the adhesive safety stop.
I couldn't reconnect this cable correctly, so my camera is not working anymore.
It doesn't matter to me, I didn't used the camera that often...
But the Ambient Light Sensor uses the camera to control keyboard lighting, so I wasn't able to see my keyboard in the dark anymore... :(
If you have the same problem, after a couple of google hits I've found this app: https://www.macupdate.com/app/mac/22151/...
Problem solved! YAY!
PS: be careful because WIFI passes through this cable as well!!!!
Look at the photo intently. The connector is inserting not in parallel, but at a slight angle. The bottom corner of the connector is slightly ahead. It is important! Singular metod to insert it.
Vladimir -
Avec votre ongle ou la pointe d'une spatule, ouvrez le clapet de retenue de la prise ZIF de la nappe du clavier.
Avec votre spatule, faites glisser la nappe du clavier hors de sa prise.
When reinserting the keyboard ribbon cable, make sure you push it in all the way (two plastic tools are helpful - one to push it down flat, the other to coax it all the way in). For 3 days after replacing a top case, my MacBook Pro 13" wouldn't start up. I thought the main logic board was fried too. However, reinserting the keyboard ribbon cable again, this time perhaps 1mm farther in, and it started up again! I did the same for the "keyboard backlight ribbon cable" (i.e. reinserted it just to make sure). Really not sure which completed the circuit so is would start, but I suspect the keyboard ribbon cable.
Citation de amiller770 :
I usually use a piece of sticky transparent office tape and stick it over the flat cable a bit further away from the mating part then pull on it. There is no better way to force the flat cable into a stiff connector without damaging the fragile cable.
As others have stated, if the keyboard ribbon cable isn't fully inserted the MBP will not power on. Leo Bodnar's recommendation to use a piece of transparent office tape did the trick for me. Many thanks Leo!
Saisissez le côté gauche de la carte mère et soulevez-la jusqu'à ce que les ports s'écartent du côté du boîtier supérieur.
Éloignez la carte mère du côté du boîtier supérieur et retirez-la en évitant que la carte de raccordement MagSafe (DC-In) ne reste accrochée.
When putting the logic board back in place, it's easier to angle the mic down in it's place as you are placing the board in, rather than after the board is seated.
Retirez deux vis cruciformes fixant le support du disque dur du boîtier.
Soulevez le support de retenue hors du boîtier.
Retirez les quatre vis suivantes fixant la nappe du disque dur et du capteur IR au boîtier :
Deux vis cruciformes de 1,5 mm
Deux vis cruciformes de 4 mm
Éloignez le support du disque dur et du capteur IR du bord du boîtier.
Décollez soigneusement la nappe du disque dur et du capteur IR du boîtier.
Retirez les deux vis extérieures Torx de 6 mm fixant de chaque côté le support de l'écran au boîtier supérieur (4 vis au total).
Saisissez le boîtier avec votre main droite et faites-le pivoter légèrement vers le haut de l'écran, de sorte que le support supérieur de l'écran s'écarte du bord du boîtier supérieur.
Faites légèrement pivoter l'écran pour l'écarter du boîtier.
Soulevez l'écran et éloignez-le du boîtier, en tenant compte des supports ou des nappes susceptibles de rester accrochés.
Retirez les quatre vis cruciformes de 1,2 mm entourées en rouge.
Délogez soigneusement le bord du trackpad le plus proche du clavier de son orifice dans le boîtier supérieur en l'écartant des supports attachés au boîtier.
Faites passer la nappe du trackpad à travers sa fente découpée dans le boîtier supérieur.
Éloignez le trackpad du bord extérieur du boîtier supérieur.
Retirez le trackpad et mettez-le de côté.
There's a missing step here. In addition to the trackpad, there's an aluminum structural piece that sits under the center of the keyboard, that has to be migrated from old to new case. It's clearly shown to the left of the repair-person's right hand in step 44.
Utilisez un tournevis Torx T6 pour visser lâchement la vis de blocage de 1,1 mm incluse avec votre nouveau boîtier dans son trou moulé près du milieu de l'orifice du trackpad sur votre nouveau boitier.
I bought a used replacement case and had to move a few parts from the old case to the replacement. This included the battery indicator cable, the clips for the trackpad and the bracket in the center of the top case. So worth it at this point to compare your old and replacement case to be sure everything you need is there.
my new case came with the set screw already installed, and i couldn’t loosen it. i didn’t want to strip it and cause a bigger problem, so i left it alone. the trackpad seems to work fine so far regardless, although i may take the bottom case off and play with it a little if i get a chance.
i also (just like Ron) had to move the trackpad clips, battery indicator and center bracket to the new case. they were not included.
Insérez soigneusement la nappe de votre ancien trackpad à travers la fente découpée dans votre nouveau boîtier.
Utilisez une main pour maintenir la nappe du trackpad en place lorsque vous insérez les deux pattes de retenue du bord extérieur du trackpad sous le rebord du boîtier supérieur.
Tirez sur la nappe du trackpad lorsque vous placez le trackpad dans son emplacement dans votre nouveau boîtier.
Serrez les deux vis extérieures le long du bord intérieur du trackpad et vérifiez l'alignement de celui-ci sur le côté extérieur du boîtier supérieur.
Si l'alignement semble bon, vissez le reste des vis cruciformes le long du bord intérieur du trackpad.
Avant de réassembler votre machine, vérifiez que la vis de blocage permet toujours à la souris de cliquer correctement.
You can actually replace the keyboard alone fairly easily! I don't know why everyone says you have to replace the whole top case, because if you've got the guts to go this far, you might as well just peel back the illuminator cover and get to work pulling all those tiny screws in the keyboard... Just be careful when peeling up the black adhesive keyboard cover, because you will need to replace it. I used the edge of the ifixit Sesame tool (very thin flat metal opening tool) to carefully slip under any bits of adhesive, and had the keyboard exposed in no time. Also be careful because the clear plastic sheet is actually the keyboard illuminator. Once under all that, it's a mere 50 or so tiny screws, 2 screws in the power button backing, and you've got the keyboard out. Use a magnetized #000 phillips, it will make life much easier than anything else.
Absolutely right. I just replaced a keyboard the same way without much problem but i just want to add that those tiny screws need extra care as the heads can get damaged very easily. If damaged, they become very difficult to remove.
Masood -
I did just that on my mid-2010 MacBook Pro about a month ago and sadly will have to do it to my wife's Early-2011 one next week. I was cleaning all the crap off her keyboard and apparently nuked the K and 0 keys on her keyboard. Probably my ply challenge was aligning the keyboard illuminator. It's still not aligned properly on mine so some keys are better lit than others, but otherwise it was a relatively easy fix and far cheaper than replacing the entire upper case.
My keyboard tasted good coffee and as a consequence keys "/", Enter, RShift, up/down arrows do not work. I was looking to replace upper casing but then saw your comment. My question is: can I get the keyboard alone, without top housing? IIUC that's exactly what you did, right? If so, where can I get the part? Cheers!
ebelin -
If I replace just the keyboard, are there any steps that I can skip?
I replaced my keyboard less than an hour ago. The biggest pain/most time consuming was reattaching the ZIF connector for the keyboard and backlight. No matter what I did I could not get the %#*@ thing to reattach. What sadist designs these things? I had to walk away from the project for an hour and finally success.
All those screws will make you go crosseyed!
It helps to put some tape along the cable going lengthwise to the cable, and then fold the end of the tape onto itself to give yourself something to hold onto. This will give you some leverage to get that puppy into the socket.
I’m glad you managed !!!
I’m suffering :( take a part about 5 times…… ordered new (used) keyboard, the same results. I tested logic board in my daughter MAC, board works 100% no trouble ……. what could be wrong? there a secret how to reassemble keyboard parts together? I ripped a little bit black plastic thing, not top one with tiny connectors……
In the end I have two keyboards, cleaned and taken a part, both of them acting identical when installed. Some keys respond by giving absolutely not relevant symbols, beeping noise come with almost every key i pressed…..
Recovering after massive cappuccino spell after surprising hug :(((((
I swear to post photo step by step, if I will achieve this one……….. assemble back to 100% working condition after total reassembling, ultrasonic cleaning and drying………. just keyboard panel.
Give me nightmares :) will be first time I have so much trouble to fix………
I'm wondering about putting it back together. Different wires and small parts etc were glued or adhered in some way to the case or sides or whatever, as it is put together in the beginning. Is that just to make it easier to put it back together? Should I try to stick them back the way they were with something? Can you use tape or glue if it's just a wire? I wouldn't want to use something that would melt...or is this not something to worry apout?
I just used 1/4 polymide tape, and iFixit double sided tape. Works like a champ.
Hmmm.... I wrote a comment but cant find it now. I asked where I might find a diagnostic page to find out what components may have been damaged by minor water spill. I opened this model A1278 Mac Air (2010?) and there was some corrosion on logic board near power connection which I cleaned off with alcohol/toothbrush. Nothing from online tips will make it power on. This is a great guide to dis-assembly but I don't know what is wrong, e.g., logic board, key board, etc. Tips on how to proceed.? Thanks.
Hi Guys could anyone please assist on where I can order the MacBook Pro top case on the internet? Many thanks :)
iFixit sells them….
I’m not sure if there’s a step missing, or if my new top case is missing a part, but I can’t work out how to remove the antenna behind the right speaker (referred to in step 35) It seems to be stuck on and I’m worried I’ll break it if I try to remove it. Are new top cases meant to come with these already installed? Mine is second hand… maybe something to look out for?
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
41 autre(s) ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
3 commentaires
Very good tutorial. Guide was 100% accurate. As mentioned, make sure you have good quality tools, and follow the guide to be certain the right get tool is used for certain screws, I did strip one screw head, in my opinion not bad considering all the tiny screws! But now my MacBook works, and save me having to spend on a new MacBook!
Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
David Kilbridge - Réponse
Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
mastover - Réponse
I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
adlerpe -
That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
joyitsjennie -
Great idea and one I use often
Thomas Overstreet -
Excellent idea! Thanks for sharing it here.
Laura Sharkey -
I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
valentinedhdh - Réponse
