Aller au contenu principal
Samsung NP510R5E-A01UB Display Replacement
Dominic Simpson
Dominic Simpson et 2 autres contributeurs
Dernière mise à jour le May 28, 2018
10 - 15 minutes
Modérée
The display for a device gives visual output for the user to interact with. This guide will help you replace it properly.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Samsung NP510R5E-A01UB Display Replacement, Hard Drive: étape 1, image 1 de 1
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  2. Samsung NP510R5E-A01UB Display Replacement: étape 2, image 1 de 1
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  3. Samsung NP510R5E-A01UB Display Replacement: étape 3, image 1 de 2 Samsung NP510R5E-A01UB Display Replacement: étape 3, image 2 de 2
    • Unplug the connector from the hard drive by pulling straight out.
  4. Samsung NP510R5E-A01UB Display Replacement, Display: étape 4, image 1 de 3 Samsung NP510R5E-A01UB Display Replacement, Display: étape 4, image 2 de 3 Samsung NP510R5E-A01UB Display Replacement, Display: étape 4, image 3 de 3
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  5. Samsung NP510R5E-A01UB Display Replacement: étape 5, image 1 de 2 Samsung NP510R5E-A01UB Display Replacement: étape 5, image 2 de 2
    • Disconnect the black and white cables by pulling up as pictured.
  6. Samsung NP510R5E-A01UB Display Replacement: étape 6, image 1 de 2 Samsung NP510R5E-A01UB Display Replacement: étape 6, image 2 de 2
    • Disconnect the black cable by pulling straight out.
  7. Samsung NP510R5E-A01UB Display Replacement: étape 7, image 1 de 3 Samsung NP510R5E-A01UB Display Replacement: étape 7, image 2 de 3 Samsung NP510R5E-A01UB Display Replacement: étape 7, image 3 de 3
    • Unscrew the two 4.45mm long screws to disconnect the left hinge.
    • Unscrew the two 4.45mm long screws to disconnect the right hinge.
    • At this point the screen and plastic housing should be completely disconnected.
  8. Samsung NP510R5E-A01UB Display Replacement: étape 8, image 1 de 2 Samsung NP510R5E-A01UB Display Replacement: étape 8, image 2 de 2
    • Using the plastic opening tool, pry open the plastic housing that holds the display.
  9. Samsung NP510R5E-A01UB Display Replacement: étape 9, image 1 de 2 Samsung NP510R5E-A01UB Display Replacement: étape 9, image 2 de 2
    • Unscrew the four 3.55mm long screws that hold the display in place.
  10. Samsung NP510R5E-A01UB Display Replacement: étape 10, image 1 de 2 Samsung NP510R5E-A01UB Display Replacement: étape 10, image 2 de 2
    • Disconnect the last cable by pulling straight out.
Dominic Simpson
Membre depuis le 02/14/18
245 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S6-G5, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S6-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S6G5
3 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 7
Total : 729
