Samsung NP510R5E-A01UB Display Replacement
Introduction
Passez à l'étape 1The display for a device gives visual output for the user to interact with. This guide will help you replace it properly.
Ce dont vous avez besoin
Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
Remove the two rubber feet with arrows by them on the back side to uncover two screws.
Unscrew the four silver 4.4mm long screws near the hard drive.
Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
