Aller au contenu principal
Samsung Older French Door Refrigerator Freezer Drawer Replacement
Bill Gilbert
Bill Gilbert et un autre contributeur
Dernière mise à jour le January 7, 2025
25 - 30 minutes
Modérée
Use this guide to replace the freezer drawer on your Samsung older French door refrigerator.
The freezer drawer serves as the access point to the freezer compartment.
If it fails the freezer will not be able to readily maintain temperature. Common failures include failed seals and failed interior skin.
This guide was created using a Samsung model RFG298HDRS French door refrigerator manufactured in 2013. Other older Samsung French door units with dual evaporators should be similar.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Samsung Older French Door Refrigerator Freezer Drawer Replacement, Freezer Drawer (Older Model): étape 1, image 1 de 2 Samsung Older French Door Refrigerator Freezer Drawer Replacement, Freezer Drawer (Older Model): étape 1, image 2 de 2
    • Open the freezer drawer.
  2. Samsung Older French Door Refrigerator Freezer Drawer Replacement: étape 2, image 1 de 3 Samsung Older French Door Refrigerator Freezer Drawer Replacement: étape 2, image 2 de 3 Samsung Older French Door Refrigerator Freezer Drawer Replacement: étape 2, image 3 de 3
    • Pull out the upper freezer drawer.
    • Lift the front edge of the drawer.
    • Remove the drawer by lifting it up and out of the freezer compartment.
  3. Samsung Older French Door Refrigerator Freezer Drawer Replacement, Remove small drawer basket: étape 3, image 1 de 3 Samsung Older French Door Refrigerator Freezer Drawer Replacement, Remove small drawer basket: étape 3, image 2 de 3 Samsung Older French Door Refrigerator Freezer Drawer Replacement, Remove small drawer basket: étape 3, image 3 de 3
    • Unclip the basket hinge retainer by tilting the rear edge up and remove it from the drawer rail.
    • Release the small drawer basket and lift it up and out.
  4. Samsung Older French Door Refrigerator Freezer Drawer Replacement, Remove the drawer basket: étape 4, image 1 de 1
    • Lift the drawer basket out of the drawer frame and remove it.
  5. Samsung Older French Door Refrigerator Freezer Drawer Replacement, Unfasten the drawer front: étape 5, image 1 de 2 Samsung Older French Door Refrigerator Freezer Drawer Replacement, Unfasten the drawer front: étape 5, image 2 de 2
    • Use a 3/8" socket wrench, box wrench, or open end wrench to remove the bolts securing the drawer front to the right drawer slide.
    • Repeat the process for the left drawer slide.
  6. Samsung Older French Door Refrigerator Freezer Drawer Replacement, Remove the drawer front: étape 6, image 1 de 3 Samsung Older French Door Refrigerator Freezer Drawer Replacement, Remove the drawer front: étape 6, image 2 de 3 Samsung Older French Door Refrigerator Freezer Drawer Replacement, Remove the drawer front: étape 6, image 3 de 3
    • Lift the drawer front upwards to free it from the drawer slides.
    • Remove the drawer front.
  7. Samsung Older French Door Refrigerator Freezer Drawer Replacement, Release the connector rod retaining pin: étape 7, image 1 de 3 Samsung Older French Door Refrigerator Freezer Drawer Replacement, Release the connector rod retaining pin: étape 7, image 2 de 3 Samsung Older French Door Refrigerator Freezer Drawer Replacement, Release the connector rod retaining pin: étape 7, image 3 de 3
    • Rotate the slide connector rod until you can access the retaining pin.
    • Use a pair of long nose pliers to squeeze the retaining pin shank to release it.
  8. Samsung Older French Door Refrigerator Freezer Drawer Replacement, Remove the drawer slide connecting rod: étape 8, image 1 de 2 Samsung Older French Door Refrigerator Freezer Drawer Replacement, Remove the drawer slide connecting rod: étape 8, image 2 de 2
    • Pull the retaining pin out of the hole.
    • Slide the connecting rod to the right to free the left end of the rod.
    • Remove the rod by lifting it upward and sliding it back to the left.
Repair didn’t go as planned? Ask our Answers Community for help.
Bill Gilbert
Membre depuis le 06/30/22
37 443 Réputation
261 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 468 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 16
Total : 43
