Aller au contenu principal
Smartab STJR700 Home Button Replacement
Moriah Wiggins
Moriah Wiggins et 5 autres contributeurs
Dernière mise à jour le May 7, 2024
40 minutes
Modérée
Découpez pour améliorer
This repair guide should only be used if all other options have been exhausted and the tablet's home button is still unresponsive. Before attempting to replace the home button, make sure the unresponsive home button is not experiencing a software issue.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Smartab STJR700 Home Button Replacement, Home Button: étape 1, image 1 de 2 Smartab STJR700 Home Button Replacement, Home Button: étape 1, image 2 de 2
    • Power off device. Place it face down. Unscrew the four perimeter screws using a PH000.
  2. Smartab STJR700 Home Button Replacement: étape 2, image 1 de 1
    • Using a plastic opening tool or metal spudger, begin to gently pry the rear case down and away from the display. Slowly wiggle the tool up and down to pry open the tablet. Once the rear case is fully removed, place it to the side.
  3. Smartab STJR700 Home Button Replacement: étape 3, image 1 de 3 Smartab STJR700 Home Button Replacement: étape 3, image 2 de 3 Smartab STJR700 Home Button Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    • Using tweezers, carefully remove the tape that is holding the black and red intertwined cables to the motherboard. Place tape to the side as it will be needed for reassembly.
  4. Smartab STJR700 Home Button Replacement: étape 4, image 1 de 1
    • Remove the two Phillips #000 screws holding the home button board to the front panel.
  5. Smartab STJR700 Home Button Replacement: étape 5, image 1 de 2 Smartab STJR700 Home Button Replacement: étape 5, image 2 de 2
    • Using tweezers, slowly and carefully remove the end of the cable that connects the home button to the main motherboard.
To ensure a successful replacement make sure to follow all steps carefully .
Moriah Wiggins
Membre depuis le 03/08/17
201 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G4, Botvin Spring 2017 Membre de l'équipe UMass Dartmouth, Team S3-G4, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G4
4 membres
5 tutoriels rédigés
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 326
