Aller au contenu principal
Sony Xperia XA1 Ultra Battery Replacement
Jacob Jung
Jacob Jung et 4 autres contributeurs
Dernière mise à jour le June 4, 2018
5 - 6 minutes
Facile
Tutoriel étudiant vedette
This guide will show you how to remove the battery from your Sony Xperia XA1 Ultra. You may need to replace the battery if it drains too fast or it can no longer charge. A heat gun or hairdryer is needed to open the back panel, which can become hot and potentially damage the phone. Additionally, a spudger is needed to lift and disconnect parts from the phone.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Sony Xperia XA1 Ultra Battery Replacement, Back Assembly: étape 1, image 1 de 2 Sony Xperia XA1 Ultra Battery Replacement, Back Assembly: étape 1, image 2 de 2
    • Wedge your finger under the bottom ridge of the SD card insert.
    • Pull outwards with your fingers to remove the SD card from the left side of device.
    How do you remove it? (Seems obvious but write for any audience, and say how to do things instead of just what to do)
    Kyle Ladtkow - Réponse
  2. Sony Xperia XA1 Ultra Battery Replacement: étape 2, image 1 de 1
    • Use a hair dryer to heat each corner of the phone.
    • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
    • Don't heat one area for too long; the phone may get damaged from overheating.
    Consider saying “loosen” instead of “soften” so that steps 2 and 3 use the same terms. Somebody may not know that heating the glue will loosen it, and so they will be confused reading “once the adhesive is loosened” in step 3.
  3. Sony Xperia XA1 Ultra Battery Replacement: étape 3, image 1 de 1
    • Press a suction cup on a heated corner of the device.
    • Hold the phone down and gently lift the suction cup to create a small gap.
    • You may hear crunching or popping sounds when you lift up the back cover.
    sure that there is adhesive tape on backcover?
    where should it tape on at the device inside?
    looks more like only plugged together`?
    Alexander H - Réponse
  4. Sony Xperia XA1 Ultra Battery Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
    • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
    Period missing for first point.
  5. Sony Xperia XA1 Ultra Battery Replacement: étape 5, image 1 de 1
    • Slide your plastic card along the side of your phone to loosen the adhesive.
    • Move the card along the sides of the phone to lift all of the corners.
    Can you clarify what should be repeated in this step?
    Tiffany Dang - Réponse
  6. Sony Xperia XA1 Ultra Battery Replacement: étape 6, image 1 de 1
    • Lift up the back cover by lifting up the sides of the phone with your hand.
    • Apply a new strip of adhesive for reassembly.
  7. Sony Xperia XA1 Ultra Battery Replacement, Battery: étape 7, image 1 de 3 Sony Xperia XA1 Ultra Battery Replacement, Battery: étape 7, image 2 de 3 Sony Xperia XA1 Ultra Battery Replacement, Battery: étape 7, image 3 de 3
    • Peel off the two pieces of black tape covering the battery with your hands.
  8. Sony Xperia XA1 Ultra Battery Replacement: étape 8, image 1 de 2 Sony Xperia XA1 Ultra Battery Replacement: étape 8, image 2 de 2
    • Use the iFixit Opening Tool to remove the flexible orange strip which connects the battery to the motherboard.
    Grammar, consider rewording. “Use the iFixit Opening Tool to remove the flexible orange strip which is connected to the battery from the motherboard” or “Use the iFixit Opening Tool to remove the flexible orange strip which connects the battery to the motherboard” or another alternative depending on your intended meaning.
    exelente, a melhor aula de celular que eu vi.
    wmestrecamaleao - Réponse
  9. Sony Xperia XA1 Ultra Battery Replacement: étape 9, image 1 de 3 Sony Xperia XA1 Ultra Battery Replacement: étape 9, image 2 de 3 Sony Xperia XA1 Ultra Battery Replacement: étape 9, image 3 de 3
    • Wedge the iFixit Opening Tool underneath the battery.
    • Remove the battery by pulling up on the iFixit Opening Tool.
12 autres ont terminé cette réparation.
Jacob Jung
Membre depuis le 04/18/18
1 429 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team S16-G3, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S16-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G3
4 membres
9 tutoriels rédigés
3 commentaires de tutoriel
magnificent…i successfully change a new battery for xperia xa1 ultra…its not the time yet for this xperia to retire from service to me…thank you very much
Wahyudi Hussaini - Réponse
Wher did you get the batterry from? And is it good as the original?
very Green -
Where can I get the original battery
very Green - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 21
Total : 10,376
