Aller au contenu principal
Sony Xperia Z Headphone Jack Replacement
Mollie
Mollie et 4 autres contributeurs
Dernière mise à jour le December 5, 2017
30 - 35 minutes
Difficile
This guide will lead you through the necessary steps required to replace the headphone jack in your phone.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Sony Xperia Z Headphone Jack Replacement, Battery: étape 1, image 1 de 3 Sony Xperia Z Headphone Jack Replacement, Battery: étape 1, image 2 de 3 Sony Xperia Z Headphone Jack Replacement, Battery: étape 1, image 3 de 3
    • Turn hair dryer to medium heat.
    • Slowly move the hair dryer along the seams on the back of the phone. Keep the dryer a few inches away from the case.
    • Circulate the dryer for a full minute to soften the adhesive binding the phone together.
  2. Sony Xperia Z Headphone Jack Replacement: étape 2, image 1 de 1
    • Once the adhesive is loosened, stick the suction cup to the top-center of the back of your phone and gently pull back.
    • Gently pull back just enough to create a small gap.
  3. Sony Xperia Z Headphone Jack Replacement: étape 3, image 1 de 2 Sony Xperia Z Headphone Jack Replacement: étape 3, image 2 de 2
    • Once you've opened a small space with the back cover, stick the plastic opening tool into the seam of the phone.
    • Move the tool along the seam to loosen the adhesive.
  4. Sony Xperia Z Headphone Jack Replacement: étape 4, image 1 de 1
    • Caution: Pulling too vigorously or quickly on the suction cup could snap the back of the phone.
    • Once the adhesive has been adequately loosened, pull back slowly on the suction cup to remove the back panel of the phone.
    • The remaining adhesive should be strong enough to hold the phone together tightly upon reassembly. However, once opened the water resistance of your phone has been compromised.
  5. Sony Xperia Z Headphone Jack Replacement: étape 5, image 1 de 3 Sony Xperia Z Headphone Jack Replacement: étape 5, image 2 de 3 Sony Xperia Z Headphone Jack Replacement: étape 5, image 3 de 3
    • Now that the back is removed, the battery is visible. You now have access to the battery and its connecting components.
    • With the plastic opening tool, gently remove the connector from the motherboard.
    • Use your fingers to peel the rest of the adhesive away from the phone.
  6. Sony Xperia Z Headphone Jack Replacement: étape 6, image 1 de 3 Sony Xperia Z Headphone Jack Replacement: étape 6, image 2 de 3 Sony Xperia Z Headphone Jack Replacement: étape 6, image 3 de 3
    • With the plastic opening tool, carefully peel the white adhesive tape up from the bottom of the battery.
    • Use your fingers to peel back the rest of the adhesive tape away from the battery.
    I found this white adhesive tape just wrapped around the battery, so didn’t need to be removed
    sarah - Réponse
  7. Sony Xperia Z Headphone Jack Replacement: étape 7, image 1 de 3 Sony Xperia Z Headphone Jack Replacement: étape 7, image 2 de 3 Sony Xperia Z Headphone Jack Replacement: étape 7, image 3 de 3
    • Slide the spudger firmly along the right side of the battery, loosening the adhesive between the casing and battery.
    • Flex cables run vertically down the phone underneath the battery and can be damaged easily. Make sure to only place the spudger in the indicated area.
    • Insert the spudger in the bottom-center to further loosen the adhesive. Carefully separate the battery from the phone by sliding the spudger vertically underneath the battery and prying up. This may take some time and work as the adhesive is very strong.
    it would be better to show in overlay red the two vertical cables that should not be touched; i damaged by 1 mm at the bottom one of the cable and the display is no longer working, even if can hear touch feedbacks and sound and now if if it charges well :o((
    cagnes06 - Réponse
    if you do what is shown on the picture at step 7 (i did) you can still damage the cable right, because it deviates at the bottom towards the left !
    cagnes06 - Réponse
    Why not start the instructions by saying "This battery replacement operation is too difficult unless you are highly experienced. You are very likely to damage the phone beyond repair. Sony prefer you to buy a new phone every 2 years when the battery fails"
    Roy Banks - Réponse
    I agree that it would be better to overlay red the two vertical cables. Other than that, this step is rather time consuming, than complicated. Obviously you should be attentive to not damage the cables, but if you put moderate force during 3-4 minutes, the battery will finally separate from the case.
    Wondering if it’s safe to use hair dryer at this step.
    strixaluco - Réponse
    Patient manuevering to extract the bat. is surely preferable to forced heat on the exposed traces and PCB.
    North Star -
  8. Sony Xperia Z Headphone Jack Replacement, Camera: étape 8, image 1 de 1
    • Remove the one 3 mm screw with the Phillips #000 screwdriver. The screw is located at the top right corner of the motherboard. The motherboard is the green/silver circuit board at the top of the phone.
  9. Sony Xperia Z Headphone Jack Replacement: étape 9, image 1 de 3 Sony Xperia Z Headphone Jack Replacement: étape 9, image 2 de 3 Sony Xperia Z Headphone Jack Replacement: étape 9, image 3 de 3
    • Using with the plastic opening tool, pry up firmly from the bottom and top of the plastic housing. The housing is black and located at the top right corner of the phone.
    • Release the charging cover, located on the right side of the phone at the top. This should cause the housing piece to pop out effortlessly.
    • Getting the black housing off of the phone can be tricky. Just keep prying and pulling up on the housing to get it out.
  10. Sony Xperia Z Headphone Jack Replacement, Rear Facing Camera: étape 10, image 1 de 3 Sony Xperia Z Headphone Jack Replacement, Rear Facing Camera: étape 10, image 2 de 3 Sony Xperia Z Headphone Jack Replacement, Rear Facing Camera: étape 10, image 3 de 3
    • Do not remove all the copper tape. Only remove the copper tape attached to the silver part of the motherboard.
    • Release the copper tape located at the top middle of the phone with a plastic opening tool. This will take some force since the adhesive is rather strong.
    • With the plastic opening tool, release the pop connector, by lifting up to release it. The pop connector should still be attached to the copper tape.
    • Pull up gently on the copper tape and pop connector to remove the back camera. It should pop out easily.
  11. Sony Xperia Z Headphone Jack Replacement, Front Facing Camera: étape 11, image 1 de 2 Sony Xperia Z Headphone Jack Replacement, Front Facing Camera: étape 11, image 2 de 2
    • With the plastic opening tool, gently pry the red tape away from motherboard. This pop connector is located at the top right corner of the phone.
    • Using your fingers, gently pull up on the pop connector to remove the front camera. The front camera piece should lift out effortlessly.
  12. Sony Xperia Z Headphone Jack Replacement, SIM Card: étape 12, image 1 de 2 Sony Xperia Z Headphone Jack Replacement, SIM Card: étape 12, image 2 de 2
    • The SIM card of the Xperia Z is located in the unlabeled slot above the power button.
    • Gently open the cover by pushing it to the left.
    • Some photos in this guide show the back cover of the phone removed. If you are only removing the SIM card, removing the case is not necessary.
  13. Sony Xperia Z Headphone Jack Replacement: étape 13, image 1 de 3 Sony Xperia Z Headphone Jack Replacement: étape 13, image 2 de 3 Sony Xperia Z Headphone Jack Replacement: étape 13, image 3 de 3
    • To avoid damage to the SIM card, be careful when removing and handling it.
    • Carefully pull the SIM card and SIM card tray out of the phone
  14. Sony Xperia Z Headphone Jack Replacement, Motherboard: étape 14, image 1 de 1
    • Remove the two 3mm Phillips #000 screws located at the middle left and lower right of motherboard.
  15. Sony Xperia Z Headphone Jack Replacement: étape 15, image 1 de 3 Sony Xperia Z Headphone Jack Replacement: étape 15, image 2 de 3 Sony Xperia Z Headphone Jack Replacement: étape 15, image 3 de 3
    • Gently pry the three flex cables away from the motherboard. They are located on the bottom right, bottom left, and top left corners of the motherboard.
    • Leave the three flex cable flaps up and away from the motherboard. Be careful not to tear the flex cables.
  16. Sony Xperia Z Headphone Jack Replacement: étape 16, image 1 de 2 Sony Xperia Z Headphone Jack Replacement: étape 16, image 2 de 2
    • With the plastic opening tool pry up the antenna located at the bottom right of the motherboard.
    • Leave the antenna up and away from the motherboard.
  17. Sony Xperia Z Headphone Jack Replacement: étape 17, image 1 de 3 Sony Xperia Z Headphone Jack Replacement: étape 17, image 2 de 3 Sony Xperia Z Headphone Jack Replacement: étape 17, image 3 de 3
    • With the plastic opening tool, firmly pry the motherboard up out of the phone case. Pry from the right side of the motherboard where the back camera was previously located.
    • Firmly lift the section up where the silver part of the motherboard comes to the edge of the green base board.
    • The motherboard has a lot of adhesive connecting it to the phone, so it will require some force to remove it.
  18. Sony Xperia Z Headphone Jack Replacement, Headphone Jack: étape 18, image 1 de 2 Sony Xperia Z Headphone Jack Replacement, Headphone Jack: étape 18, image 2 de 2
    • Place the plastic opening tool under the bottom side of the orange pop connector, and lift up towards the center of the headphone jack. The pop connector is located at the top left of the phone.
    • Carefully lift the tool upwards to release the headphone jack. You may grab the sensor cable to lift the part out of its position.
13 autres ont terminé cette réparation.
Mollie
Membre depuis le 01/29/14
1 866 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 2-7, Amido Winter 2014 Membre de l'équipe Cal Poly, Team 2-7, Amido Winter 2014
CPSU-AMIDO-W14S2G7
4 membres
25 tutoriels rédigés
2 commentaires de tutoriel
How many pins are on the ribbon cable that conects the screen to the motherboard?
Email me at xenoffline@gmail.com
Xenon Line - Réponse
Excellent guide Mollie. Superb and very detailed, including the tools and warnings needed. Will this guide help with my Sony Xperia Z5 Premium? It has a defective earphones jack that needs to be replaced. Thanks for your reply.
HENRY POWER - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 51,521
