Aller au contenu principal
Sony Xperia Z1 Compact Battery Replacement
kinan badr
kinan badr et 5 autres contributeurs
Dernière mise à jour le August 13, 2019
50 minutes
Modérée
The Battery of the phone can become worn with continued use. This guide will show you how to remove the Battery of Sony Xperia Z1 Compact.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Sony Xperia Z1 Compact Battery Replacement, Back Cover: étape 1, image 1 de 1
    • Heat along the edges of the back cover using a heat gun to soften the glue.
  2. Sony Xperia Z1 Compact Battery Replacement: étape 2, image 1 de 1
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
  3. Sony Xperia Z1 Compact Battery Replacement: étape 3, image 1 de 2 Sony Xperia Z1 Compact Battery Replacement: étape 3, image 2 de 2
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
  4. Sony Xperia Z1 Compact Battery Replacement, Battery: étape 4, image 1 de 2 Sony Xperia Z1 Compact Battery Replacement, Battery: étape 4, image 2 de 2
    • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
  5. Sony Xperia Z1 Compact Battery Replacement: étape 5, image 1 de 2 Sony Xperia Z1 Compact Battery Replacement: étape 5, image 2 de 2
    • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
    The replacement batteries probably come without the new NFC sticker, so you’ll have to transfer it from the original one to the replacement. This can be easily done with an iPlastix and a good amount of isopropyl alcohol. Do this carefully.
    Stefano Restuccia - Réponse
  6. Sony Xperia Z1 Compact Battery Replacement: étape 6, image 1 de 1
    • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
  7. Sony Xperia Z1 Compact Battery Replacement: étape 7, image 1 de 1
    • Remove the battery from the device
12 autres ont terminé cette réparation.
kinan badr
Membre depuis le 09/21/17
386 Réputation
1 tutoriel rédigé
Équipe
Washington State, Team S4-G1, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S4-G1, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S4G1
6 membres
9 tutoriels rédigés
3 commentaires de tutoriel
is there any reliable source for good replacement battery purchase?
Upendra Gandhi - Réponse
What is the Ariel stuck on the battery ?
Tony - Réponse
NFC Antenna. You should carefully transplant it to new battery, in case your new battery is without one (what is the case for most 3rd party batteries available)
Peter Pepo -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 49
Total : 11,795
