Aller au contenu principal
SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement
Avinash Vadlamudi
Avinash Vadlamudi et 4 autres contributeurs
Dernière mise à jour le June 29, 2022
25 - 40 minutes
Difficile
Tutoriel étudiant vedette
The GameDAC control wheel is the component that controls the dial of the GameDAC. This electrical component is called a potentiometer. When replacing the potentiometer, one should be careful of wired connections on the circuit board. Follow this guide to safely replace the potentiometer.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: étape 1, image 1 de 3 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: étape 1, image 2 de 3 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: étape 1, image 3 de 3
    • Remove the plastic cover using the iFixit opening tool to pry the cover open.
    • Insert opening picks to keep the cover open as you work your way around the GameDAC.
    • Pop the cover off.
  2. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: étape 2, image 1 de 2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: étape 2, image 2 de 2
    • Remove the control wheel from the GameDAC by pulling on the knob.
  3. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: étape 3, image 1 de 2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: étape 3, image 2 de 2
    • Remove the five 6mm screws using the Phillips #0 driver head.
    • There is one screw hidden on the upper right-hand side of the display.
  4. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: étape 4, image 1 de 2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: étape 4, image 2 de 2
    • Hold the sides of the GameDAC and pull apart.
    • Don't pull the two sides apart quickly or forcefully to avoid tearing the wire connection between the two boards.
  5. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: étape 5, image 1 de 1
    • Remove the three 4mm screws from the circuit board using the Phillips #0 driver head.
  6. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: étape 6, image 1 de 2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: étape 6, image 2 de 2
    • Desolder the seven potentiometer pins from the board to remove the button.
    • For help desoldering connections, follow this useful guide on Comment souder et dessouder des connexions.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
5 autres ont terminé cette réparation.
Avinash Vadlamudi
Membre depuis le 01/24/19
469 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S18-G1, White Winter 2019 Membre de l'équipe Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
4 membres
21 tutoriels rédigés
3 commentaires de tutoriel
Hi there,
do you know what type of potentiometer is needed?
Greetings
Chris
Christian Humann - Réponse
I would like to know too. Cause it failed for me as well!!
Antonis Lazarakis - Réponse
Can I replace the Oled Screen with 2,42 inch arduino oled display that also have 24pin flex?
Muso!27 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 15
30 derniers jours : 101
Total : 5,271
