Aller au contenu principal
SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement
Kyle Chang
Kyle Chang et 4 autres contributeurs
Dernière mise à jour le June 29, 2022
25 - 35 minutes
Difficile
If you need to replace your GameDAC secondary control button, there are a couple of wire connections one needs to be careful for when opening the GameDAC. Follow this guide to safely access and replace the button from the circuit board.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement, GameDAC Secondary Button: étape 1, image 1 de 3 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement, GameDAC Secondary Button: étape 1, image 2 de 3 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement, GameDAC Secondary Button: étape 1, image 3 de 3
    • Remove the plastic cover using the iFixit opening tool to pry the cover open.
    • Insert opening picks to keep the cover open as you work your way around the GameDAC.
    • Pop the cover off.
  2. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: étape 2, image 1 de 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: étape 2, image 2 de 2
    • Remove the control wheel from the GameDAC by pulling on the knob.
  3. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: étape 3, image 1 de 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: étape 3, image 2 de 2
    • Remove the five 6mm screws using the Phillips #0 driver head.
    • There is one screw hidden on the upper right-hand side of the display.
  4. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: étape 4, image 1 de 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: étape 4, image 2 de 2
    • Hold the sides of the GameDAC and pull apart.
    • Don't pull the two sides apart quickly or forcefully to avoid tearing the wire connection between the two boards.
  5. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: étape 5, image 1 de 1
    • Remove the three 4mm screws from the circuit board using the Phillips #0 driver head.
  6. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: étape 6, image 1 de 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: étape 6, image 2 de 2
    • Desolder the four button pins from the board to remove the button.
    • For help desoldering connections, follow this useful guide on Comment souder et dessouder des connexions.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
3 autres ont terminé cette réparation.
Kyle Chang
Membre depuis le 01/24/19
1 170 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team S18-G1, White Winter 2019 Membre de l'équipe Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
4 membres
21 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 1,361
