Aller au contenu principal
TI-84 Plus Disassembly
martijn muntenaar
martijn muntenaar et 4 autres contributeurs
Dernière mise à jour le December 6, 2022
10 minutes
Modérée
Tutoriel réalisé par la communauté
Ce dont vous avez besoin
Outils
Afficher plus…
  1. TI-84 Plus Disassembly, flip: étape 1, image 1 de 2 TI-84 Plus Disassembly, flip: étape 1, image 2 de 2
    • Be sure the calculator is powered off before proceeding.
    • Take off the sliding cover, and flip your calculator to the back side.
  2. TI-84 Plus Disassembly, battery plate.: étape 2, image 1 de 2 TI-84 Plus Disassembly, battery plate.: étape 2, image 2 de 2
    • Press down on the latch, then remove the battery cover.
  3. TI-84 Plus Disassembly, take out the batteries: étape 3, image 1 de 2 TI-84 Plus Disassembly, take out the batteries: étape 3, image 2 de 2
    • Remove the batteries.
    • You can use the battery cover as a plate to keep the batteries.
  4. TI-84 Plus Disassembly, back up battery: étape 4, image 1 de 3 TI-84 Plus Disassembly, back up battery: étape 4, image 2 de 3 TI-84 Plus Disassembly, back up battery: étape 4, image 3 de 3
    • Removing this battery will clear your RAM, so be sure that you have made any backups of important data.
    • Use a Phillips #0 to remove the plate from the back up battery.
  5. TI-84 Plus Disassembly, backup battery: étape 5, image 1 de 2 TI-84 Plus Disassembly, backup battery: étape 5, image 2 de 2
    • remove the backup battery with either a screwdriver or the spudger.
  6. TI-84 Plus Disassembly: étape 6, image 1 de 1
    • you can use a t6 or tr6 take out all six marked screws
    What screwdriver was used in this step. ( not the bit the actual screw. driver
    Graham Denney - Réponse
  7. TI-84 Plus Disassembly, cracking the case: étape 7, image 1 de 3 TI-84 Plus Disassembly, cracking the case: étape 7, image 2 de 3 TI-84 Plus Disassembly, cracking the case: étape 7, image 3 de 3
    • Use a prying tool to get a pick into the side and then move it down until its open.
10 autres ont terminé cette réparation.
martijn muntenaar
Membre depuis le 12/20/18
735 Réputation
1 tutoriel rédigé
1 commentaire de tutoriel
Nice! My calculator wasn't turning on, took it apart and rebent the contacts for the batteries, works great now!
Noah Molla - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 37
30 derniers jours : 156
Total : 11,244
