Aller au contenu principal
Tea Kettle Switch Replacement
Anniek Moll
Anniek Moll et 4 autres contributeurs
Dernière mise à jour le November 22, 2021
15 minutes
Facile
Meilleure introduction
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Tea Kettle Switch Replacement, Switch: étape 1, image 1 de 3 Tea Kettle Switch Replacement, Switch: étape 1, image 2 de 3 Tea Kettle Switch Replacement, Switch: étape 1, image 3 de 3
    • Before you start, disconnect the device from its power source.
    • Remove the two bottom screws.
    • Remove the two top screws.
    • Remove the handle from the kettle.
  2. Tea Kettle Switch Replacement: étape 2, image 1 de 2 Tea Kettle Switch Replacement: étape 2, image 2 de 2
    • Pull out the switch.
    • If you pull too hard, you may dislodge another part as well as the spring that are both positioned behind the switch.
  3. Tea Kettle Switch Replacement: étape 3, image 1 de 1
    • Click the replacement switch back into the handle part.
    Sorry, but I’m not clear on this—are you actually putting back the same switch you took out? Or is there a replacement part to obtain which isn’t listed at the beginning? Thanks!
    April - Réponse
    Hi April, The title of the article is Tea Kettle switch replacement.
    Jonny Hall -
  4. Tea Kettle Switch Replacement: étape 4, image 1 de 1
    • Insert the light back into the switch.
    • This might take some extra attention, so be precise.
  5. Tea Kettle Switch Replacement: étape 5, image 1 de 1
    • Place the handle part back on the frame.
  6. Tea Kettle Switch Replacement: étape 6, image 1 de 1
    • Plug in the kettle.
    • Press down on the switch to check if it works again.
6 autres ont terminé cette réparation.
3 commentaires de tutoriel
How much would it cost to repair this kettle switch live points?
Bheki Valoyi - Réponse
How much would it cost to fix the tea kettle switch live points?
Can the kettle gadgets be replaced with another one
Michael Ombech - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 17
30 derniers jours : 71
Total : 26,171
