Aller au contenu principal
Toshiba Satellite C55D-A5304 Fan Replacement
Emily Verre
Emily Verre et 4 autres contributeurs
Dernière mise à jour le June 11, 2023
2 - 10 minutes
Facile
Nécessite plus d'images
Étapes manquantes
If your Toshiba Satellite C55D-A5304 is running uncomfortably hot, use this guide to clean out the fan of any debris that is resulting in clogging.
The fan keeps the inner components of the motherboard cool and prevents them from overheating.
Warning: Remove the battery beforehand to avoid any safety issues.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Toshiba Satellite C55D-A5304 Fan Replacement, Battery: étape 1, image 1 de 1
    • Make sure that the laptop is disconnected from all power sources and turned off.
    • Start with computer upside down with battery slot facing up.
  2. Toshiba Satellite C55D-A5304 Fan Replacement: étape 2, image 1 de 1
    • Use the buttons of the sides of the battery to slide inwards and release the battery.
  3. Toshiba Satellite C55D-A5304 Fan Replacement: étape 3, image 1 de 1
    • Take the battery out.
  4. Toshiba Satellite C55D-A5304 Fan Replacement, Fan: étape 4, image 1 de 1
    • Open the back of the laptop using a pry tool.
  5. Toshiba Satellite C55D-A5304 Fan Replacement: étape 5, image 1 de 1
    • Once you see the fan, to make the cleaning process more convenient use a screwdriver to unscrew the 4mm screws on the fan.
    • To the immediate right of the fan the wiring harness is located. Disconnect this also to remove the fan.
  6. Toshiba Satellite C55D-A5304 Fan Replacement: étape 6, image 1 de 1
    • Use a microfiber cloth and/or compressed air to clear any dust or clogging.
Emily Verre
Membre depuis le 03/13/23
211 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-1, Petersen Spring 2023 Membre de l'équipe UMass Dartmouth, Team 3-1, Petersen Spring 2023
UMASSD-PETERSEN-S23S3G1
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 3
Total : 122
