Aller au contenu principal
Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): étape 1, image 1 de 2 Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): étape 1, image 2 de 2
    • Turn the laptop over and place upside down on a flat surface.
    • Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
  2. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement: étape 2, image 1 de 1
    • Take two fingers and gently pull the two metal tabs away from the RAM module as shown.
    • There are two tabs for each of the two RAM modules.
    • The RAM module should be slightly dislodged from the base after the two tabs are pulled.
  3. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement: étape 3, image 1 de 1
    • Grip the edge of the card and slide the RAM module out by pulling horizontally.
    • Once the first RAM module has been removed, repeat steps 2 and 3 to remove the second RAM module.
3 autres ont terminé cette réparation.
Shelby Kunz
Membre depuis le 04/19/13
57 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 2-20, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 2-20, Maness Spring 2013
CPSU-MANESS-S13S2G20
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 14
Total : 2,917
