Aller au contenu principal
Toshiba Satellite CL15t-B1204X Network Card Replacement
Royce Alexander Porter
Royce Alexander Porter et 2 autres contributeurs
Dernière mise à jour le January 2, 2019
10 minutes
Modérée
Meilleure introduction
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Toshiba Satellite CL15t-B1204X Network Card Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Network Card Replacement: étape 2, image 1 de 1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Network Card Replacement: étape 3, image 1 de 1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Network Card Replacement: étape 4, image 1 de 1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Network Card Replacement: étape 5, image 1 de 1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Network Card Replacement: étape 6, image 1 de 1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Network Card Replacement, Network Card: étape 7, image 1 de 2 Toshiba Satellite CL15t-B1204X Network Card Replacement, Network Card: étape 7, image 2 de 2
    • Peel off the black antenna stuck to the card.
  8. Toshiba Satellite CL15t-B1204X Network Card Replacement: étape 8, image 1 de 2 Toshiba Satellite CL15t-B1204X Network Card Replacement: étape 8, image 2 de 2
    • Carefully use the PH1 screw head to unscrew the one 3mm screw on the network card found near the hinge at the top.
  9. Toshiba Satellite CL15t-B1204X Network Card Replacement: étape 9, image 1 de 1
    • Remove the network card.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 247
