Toshiba Satellite L305-S5946 LCD Screen Replacement
Introduction
Passez à l'étape 1Use this guide to remove or replace the screen in your Toshiba Satellite L305-S5946. This may be necessary if the screen is blank when the computer is on.
Ce dont vous avez besoin
Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
Place the laptop upside-down with the display hinges facing away from you.
For the following steps, use a Phillips #1 screwdriver.
Remove the twelve 6-mm screws that border the bottom of the laptop.
Remove the 6-mm screw located in the lower middle of the device.
Remove the three 3-mm screws located in the battery bay.
Remove the one 4-mm screw located near the RAM.
Using a Philips #1 screwdriver, remove the four 6-mm screws from the two metal tabs that connect the screen to the body.
