Aller au contenu principal
Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement
Sing Yang Cheng
Sing Yang Cheng et un autre contributeur
Dernière mise à jour le June 12, 2023
10 - 20 minutes
Modérée
Tutoriel étudiant vedette
If your CD/DVDs aren’t being read or even if your drive just makes too much noise with a disk in, this guide will assist you in removing the CD Drive from the computer entirely if it needs tweaking or replacement.
Ce dont vous avez besoin
Outils
  1. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement, Optical Drive (Disk Drive): étape 1, image 1 de 1
    • Power off your laptop before beginning disassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: étape 2, image 1 de 2 Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: étape 2, image 2 de 2
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: étape 3, image 1 de 2 Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: étape 3, image 2 de 2
    • The 5.3 mm Phillips #1 screw boxed in red is located on the right panel that house the RAM on the underside of the computer.
    • Remove the screw securing the drive on the plastic edge.
  4. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: étape 4, image 1 de 1
    • Use a screwdriver or a metal spludgers to push the metal piece attached to the drive in the direction of the drive opens until the drive pops out of its socket.
  5. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: étape 5, image 1 de 1
    • Fully remove the drive by pulling it all the way out of its socket.
Sing Yang Cheng
Membre depuis le 10/20/16
501 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Membre de l'équipe UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 650
