Aller au contenu principal
Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement
Torey
Torey et 3 autres contributeurs
Dernière mise à jour le June 27, 2014
3 minutes
Facile
Conditions préalables incohérentes
This guide will help you replace your CD drive if you've determined that it is no longer working.
Ce dont vous avez besoin
Outils
  1. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement, CD/DVD Drive: étape 1, image 1 de 2 Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement, CD/DVD Drive: étape 1, image 2 de 2
    • Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
  2. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: étape 2, image 1 de 1
    • Remove the panel, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: étape 3, image 1 de 1
    • Unscrew the 3.9 mm screw located at the bottom right of the panel.
  4. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: étape 4, image 1 de 1
    • Use a plastic opening tool to pry the CD drive out of the casing.
  5. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: étape 5, image 1 de 1
    • Once the CD drive is out far enough to grip, pull the CD drive out to the right.
Torey
Membre depuis le 01/31/13
210 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 7-7, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 2,306
