Toshiba Satellite L755D-S5150 Battery Removal
Introduction
Passez à l'étape 1Anytime you perform "surgery" on your laptop, you always want to make sure you're not connected to power. Even though you can unplug your laptop from the wall, you should always make sure to remove the battery, too.
After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
2 autres ont terminé cette réparation.
Un commentaire
I've got a trouble when I try to charge the battery, when I plug in the power supply charger at the laptop it is lit led one and three in the front panel, that is OK, but after a few seconds all leds blinking and the charge is breaking on the screen appear no battery plug in. I replaced the battery pack for a new one, but the trouble continuos……
