Aller au contenu principal
Toshiba Satellite L755D-S5150 Keyboard Replacement
Shaheedah
Shaheedah et 6 autres contributeurs
Dernière mise à jour le December 28, 2016
Aucune estimation
Modérée
Before taking out the keyboard it is good to know that this is the last resort to your problem. Make sure that you are in an area with space because many things will be removed and you do not want to lose them.
Ce dont vous avez besoin
Outils
  1. Toshiba Satellite L755D-S5150 Keyboard Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite L755D-S5150 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Keyboard Replacement, Keyboard: étape 2, image 1 de 1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Keyboard Replacement: étape 3, image 1 de 1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Keyboard Replacement: étape 4, image 1 de 1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
Replace after you are done with your goal replacement.
Shaheedah
Membre depuis le 10/06/16
276 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 2-5, Sullivan Fall 2016 Membre de l'équipe USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 5
Total : 900
