Aller au contenu principal
Toshiba Satellite L775D-S7340 Keyboard Replacement
Madeline Park
Madeline Park et 4 autres contributeurs
Dernière mise à jour le June 14, 2024
5 minutes
Modérée
Meilleure introduction
This guide will show you how to remove and replace the keyboard.
Ce dont vous avez besoin
Outils
  • iFixit Opening Tool
    iFixit Opening Tool
  • T4 Torx Screwdriver
    T4 Torx Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. Toshiba Satellite L775D-S7340 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 Keyboard Replacement: étape 2, image 1 de 1
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 Keyboard Replacement: étape 3, image 1 de 1
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 Keyboard Replacement, Keyboard: étape 4, image 1 de 1
    • Pry up the thin narrow strip of facing above the keyboard using the opening tool.
  5. Toshiba Satellite L775D-S7340 Keyboard Replacement: étape 5, image 1 de 1
    • Remove the four screws securing the keyboard using the T4 Torx screwdriver,
  6. Toshiba Satellite L775D-S7340 Keyboard Replacement: étape 6, image 1 de 2 Toshiba Satellite L775D-S7340 Keyboard Replacement: étape 6, image 2 de 2
    • Lift the keyboard slowly using the opening tool and lean it toward touchpad.
    • It will still be held by the connector ribbon. Make sure not to pull out the connector ribbon.
  7. Toshiba Satellite L775D-S7340 Keyboard Replacement: étape 7, image 1 de 1
    • The ribbon is attached by a white clip. Wedge the white clip up carefully using the spudger. This will release the connector ribbon and you can now remove the keyboard.
Madeline Park
Membre depuis le 09/21/17
441 Réputation
4 tutoriels rédigés
Équipe
Washington State, Team S4-G120, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S4-G120, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S4G120
6 membres
7 tutoriels rédigés
Un commentaire
I need to know how to change a plasma for a Toshiba Satellite L775D-S7340
Cyndi May Evans - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 4
Total : 1,756
