Aller au contenu principal
Toshiba Satellite L855-S5119 Random Access Memory Replacement
Cody Brannen
Cody Brannen et 4 autres contributeurs
Dernière mise à jour le June 11, 2023
2 minutes
Facile
This guide will inform readers on how to replace random access memory because of bad random access memory or the need for more.
Ce dont vous avez besoin
Outils
  1. Toshiba Satellite L855-S5119 Random Access Memory Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop face down to expose the back.
    • Locate the battery.
  2. Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 2, image 1 de 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 2, image 2 de 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 2, image 3 de 3
    • Locate the battery latches. The battery latch mechanism can be compared to a door -- The right latch, when pushed right, unlocks the battery, while the left latch, when pushed left, releases the battery, pushing it out from its container.
    • Push the latch on the right to the right to unlock the battery latch locking mechanism.
    • Push the battery latch on the left to the left to unlock the battery.
  3. Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 3, image 1 de 2 Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 3, image 2 de 2
    • With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
    • The battery will come free.
  4. Toshiba Satellite L855-S5119 Random Access Memory Replacement, Back Plate Removal: étape 4, image 1 de 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement, Back Plate Removal: étape 4, image 2 de 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement, Back Plate Removal: étape 4, image 3 de 3
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  5. Toshiba Satellite L855-S5119 Random Access Memory Replacement, Random Access Memory: étape 5, image 1 de 1
    • Locate the Random Access Memory.
  6. Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 6, image 1 de 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 6, image 2 de 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: étape 6, image 3 de 3
    • Pull back the two retention clips holding the RAM in place allowing it to pop up.
    • Remove the RAM by pulling it from the SO-DIMM slot.
2 autres ont terminé cette réparation.
Cody Brannen
Membre depuis le 02/12/18
213 Réputation
1 tutoriel rédigé
Équipe
Washington State, Team S1-G5, Lobnitz Spring 2018 Membre de l'équipe Washington State, Team S1-G5, Lobnitz Spring 2018
WSU-LOBNITZ-S18S1G5
4 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 11
Total : 454
