Aller au contenu principal
Toshiba Satellite P105-S6147 Keyboard Replacement
Benjamin Wilkinson
Benjamin Wilkinson et 5 autres contributeurs
Dernière mise à jour le December 9, 2019
5 - 10 minutes
Facile
This is a replacement guide for the Toshiba Satellite P105-S6147 Keyboard. This part’s purpose is to perform functions and input text. Replace this part if the keyboard is unresponsive, there are many missing keys, or the keys continue to stick after cleaning. Refer to this troubleshooting guide before replacing the keyboard.
All the tools you will need in this guide can be found in the iFixit Pro Toolkit. We suggest you perform this replacement on a large, level workspace where you can avoid knocking small parts onto the floor. Label any small parts so you know where to put them when reassembling the laptop.
Consult the Toshiba Satellite P105-S6147 Device Page for further questions.
Ce dont vous avez besoin
Outils
  1. Toshiba Satellite P105-S6147 Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Use the iFixit opening tool to remove the cover at the top of the keyboard.
    • Insert the tool in the small space above the keyboard and gently pry until the cover pops out of its retaining clips.
    • Repeat the prying across the top of the keyboard until the whole cover is loose.
  2. Toshiba Satellite P105-S6147 Keyboard Replacement: étape 2, image 1 de 1
    • Gently lift the cover off the top of the keyboard.
  3. Toshiba Satellite P105-S6147 Keyboard Replacement: étape 3, image 1 de 2 Toshiba Satellite P105-S6147 Keyboard Replacement: étape 3, image 2 de 2
    • Use the Phillips #0 screwdriver to remove six 6 mm screws labeled “F4” at the top of the keyboard.
  4. Toshiba Satellite P105-S6147 Keyboard Replacement: étape 4, image 1 de 3 Toshiba Satellite P105-S6147 Keyboard Replacement: étape 4, image 2 de 3 Toshiba Satellite P105-S6147 Keyboard Replacement: étape 4, image 3 de 3
    • Use the iFixit opening tool to pry the keyboard out of its retaining clips.
    • Insert the tool into the groove surrounding the laptop and pry until the keyboard “pops” out of the laptop body.
    • Once the keyboard is free from the laptop body, gently flip the keyboard over, as seen in the third picture.
  5. Toshiba Satellite P105-S6147 Keyboard Replacement: étape 5, image 1 de 2 Toshiba Satellite P105-S6147 Keyboard Replacement: étape 5, image 2 de 2
    • Lay the keyboard down on the bottom of the laptop, as seen in image one.
    • Locate the ribbon cable connecting the bottom of the keyboard to the laptop. There will be a small black and white clip securing the ribbon cable to the laptop.
    • Use the iFixit opening tool to gently open the clip, freeing the ribbon cable from the laptop body.
    • Gently remove the keyboard from the laptop body.
2 autres ont terminé cette réparation.
Benjamin Wilkinson
Membre depuis le 09/21/18
905 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 15
Total : 277
