Toshiba Satellite P855-S5102 Optical Disk Drive Replacement
Introduction
Passez à l'étape 1The Optical Disk Drive allows the laptop to read compact disks (CDs), DVDs and even Blue Ray disks using a laser light.The drive can also write to optical disks.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Tweezers$4.99
Use a set of small tweezers to pull the 10 rubber caps out of the back panel.
Remove the 3mm Phillips #0 screw from the back of the optical disk drive.
Slide the optical drive out of the side of the laptop and remove.
