Aller au contenu principal
UTILITECH #HVT-8H Motor Replacement
Joseph Pemberton
Joseph Pemberton et un autre contributeur
Dernière mise à jour le May 30, 2024
45 minutes - 1 heure
Modérée
If you have ever noticed a gradual decrease in performance from your 8-inch UTILITECH #HVT-8H desk fan, it may be time to replace the motor. The culprit for the fan's failure is typically periods of dust buildup, which can destroy the fan's motor if not cleaned.
Generally, people choose to throw away their desktop fans because it does not seem worth the hassle to fix the broken parts. Trashing the fan is not only a waste of all the other parts that are in good condition, but also a waste of money. Buying a new fan can be four times as expensive as replacing the motor. Additionally, it is beneficial to learn how to fix things, especially when there is little risk involved.
Before you begin the repair, be sure to unplug the fan from the power outlet. Also prepare plenty of space for this repair to ensure an ample amount of room for all the components to rest on.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. UTILITECH #HVT-8H Motor Replacement, Motor: étape 1, image 1 de 1
    • Use a spudger to remove the screw covers.
    • Pry gently to avoid breaking the clips.
  2. UTILITECH #HVT-8H Motor Replacement: étape 2, image 1 de 3 UTILITECH #HVT-8H Motor Replacement: étape 2, image 2 de 3 UTILITECH #HVT-8H Motor Replacement: étape 2, image 3 de 3
    • Use your Phillips #0 screwdriver to remove the 8 mm screw that attaches the fan to its stand.
    • Repeat step 1 and 2 on the other side of the fan.
  3. UTILITECH #HVT-8H Motor Replacement: étape 3, image 1 de 2 UTILITECH #HVT-8H Motor Replacement: étape 3, image 2 de 2
    • Use a spudger to remove the silver screw cover from the front of the fan.
    • Do not try to force the piece off as it could break. Instead, gently pry around the entire fan until it pops loose.
  4. UTILITECH #HVT-8H Motor Replacement: étape 4, image 1 de 2 UTILITECH #HVT-8H Motor Replacement: étape 4, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the four 6 mm screws that hold the fan cover in place.
  5. UTILITECH #HVT-8H Motor Replacement: étape 5, image 1 de 3 UTILITECH #HVT-8H Motor Replacement: étape 5, image 2 de 3 UTILITECH #HVT-8H Motor Replacement: étape 5, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the two 8 mm screws that attach the motor assembly to the base of the fan.
  6. UTILITECH #HVT-8H Motor Replacement: étape 6, image 1 de 3 UTILITECH #HVT-8H Motor Replacement: étape 6, image 2 de 3 UTILITECH #HVT-8H Motor Replacement: étape 6, image 3 de 3
    • Remove the power control knob by pulling on the knob backward.
    • Use a 10 mm socket wrench to remove the 10 mm nut that holds the power control piece in place.
  7. UTILITECH #HVT-8H Motor Replacement: étape 7, image 1 de 2 UTILITECH #HVT-8H Motor Replacement: étape 7, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the two 8 mm screws that fasten the power plug to the base.
  8. UTILITECH #HVT-8H Motor Replacement: étape 8, image 1 de 3 UTILITECH #HVT-8H Motor Replacement: étape 8, image 2 de 3 UTILITECH #HVT-8H Motor Replacement: étape 8, image 3 de 3
    • Cut the two black cables to release them from the motor assembly.
    • Be sure to cut as closely as you can to the base of the cables so you don't lose a lot of length.
  9. UTILITECH #HVT-8H Motor Replacement: étape 9, image 1 de 2 UTILITECH #HVT-8H Motor Replacement: étape 9, image 2 de 2
    • Use a wire stripper on the black wires to expose the metal underneath the rubber.
    • Strip about 13 mm from the end of both wires.
  10. UTILITECH #HVT-8H Motor Replacement: étape 10, image 1 de 2 UTILITECH #HVT-8H Motor Replacement: étape 10, image 2 de 2
    • Connect the exposed power plug wires to the new motor assembly by twisting the two exposed wires together.
    • Wrap electrical tape around the newly connected wires.
Joseph Pemberton
Membre depuis le 02/26/24
181 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 14
Total : 377
