Aller au contenu principal
VTech InnoTab Max Battery Replacement
Jacob Schioppo
Jacob Schioppo et 4 autres contributeurs
Dernière mise à jour le March 4, 2024
10 - 20 minutes
Modérée
This guide will show how to replace the battery in the VTech InnoTab Max.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. VTech InnoTab Max Battery Replacement, Cover: étape 1, image 1 de 3 VTech InnoTab Max Battery Replacement, Cover: étape 1, image 2 de 3 VTech InnoTab Max Battery Replacement, Cover: étape 1, image 3 de 3
    • Remove all screw caps from the back panel using a metal spudger.
  2. VTech InnoTab Max Battery Replacement: étape 2, image 1 de 3 VTech InnoTab Max Battery Replacement: étape 2, image 2 de 3 VTech InnoTab Max Battery Replacement: étape 2, image 3 de 3
    • Next remove all of the now uncovered screws.
    • If there is a cartridge in the device make sure to remove it.
  3. VTech InnoTab Max Battery Replacement: étape 3, image 1 de 2 VTech InnoTab Max Battery Replacement: étape 3, image 2 de 2
    • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
  4. VTech InnoTab Max Battery Replacement: étape 4, image 1 de 2 VTech InnoTab Max Battery Replacement: étape 4, image 2 de 2
    • Here you can see the back cover has been fully removed and you can now access the front cover.
    • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
  5. VTech InnoTab Max Battery Replacement, Battery: étape 5, image 1 de 1
    • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
  6. VTech InnoTab Max Battery Replacement: étape 6, image 1 de 3 VTech InnoTab Max Battery Replacement: étape 6, image 2 de 3 VTech InnoTab Max Battery Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
    • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
    • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
  7. VTech InnoTab Max Battery Replacement: étape 7, image 1 de 3 VTech InnoTab Max Battery Replacement: étape 7, image 2 de 3 VTech InnoTab Max Battery Replacement: étape 7, image 3 de 3
    • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
  8. VTech InnoTab Max Battery Replacement: étape 8, image 1 de 1
    • The battery is now fully disconnected.
7 autres ont terminé cette réparation.
Jacob Schioppo
Membre depuis le 02/15/17
564 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S5-G5, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
3 membres
10 tutoriels rédigés
10 commentaires de tutoriel
Thank you for the useful guide!
Which battery (exact specs) can be used as a replacement?
kermit - Réponse
Where can we purchase a replacement battery
Frank Godon - Réponse
Where can we buy a replacement battery
Nice of you to show this, but I can not find that particular battery anywhere. Not even the China website.
Let us know where we can get the battery.
Donald Josefczyk - Réponse
Since it seems like a replacement battery cannot be purchased anywhere, can the battery be bypassed to still use it plugged in? I know it defeats the purpose of a tablet, but it would be nice to still use it. Anyone have suggestions?
ktmm - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 63
Total : 14,737
