Aller au contenu principal
WRS315SDHW Control Board Replacement
nicO
nicO et 3 autres contributeurs
Dernière mise à jour le June 1, 2023
15 - 30 minutes
Modérée
Use this guide to replace the control board in your Whirlpool WRS315SDHW Refrigerator.
The control board processes the inputs for the dispenser assembly and other related assemblies. If your refrigerator is not dispensing properly, or if the dispenser buttons on your refrigerator aren't working, then your control board might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
  1. WRS315SDHW Control Board Replacement, Safety precautions: étape 1, image 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: étape 2, image 1 de 2 WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: étape 2, image 2 de 2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the two dispenser panels.
  3. WRS315SDHW Control Board Replacement, Remove the dispenser panels: étape 3, image 1 de 3 WRS315SDHW Control Board Replacement, Remove the dispenser panels: étape 3, image 2 de 3 WRS315SDHW Control Board Replacement, Remove the dispenser panels: étape 3, image 3 de 3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. WRS315SDHW Control Board Replacement, Unfasten the control board: étape 4, image 1 de 1
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the control board.
  5. WRS315SDHW Control Board Replacement: étape 5, image 1 de 3 WRS315SDHW Control Board Replacement: étape 5, image 2 de 3 WRS315SDHW Control Board Replacement: étape 5, image 3 de 3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. WRS315SDHW Control Board Replacement, Disconnect the control board: étape 6, image 1 de 3 WRS315SDHW Control Board Replacement, Disconnect the control board: étape 6, image 2 de 3 WRS315SDHW Control Board Replacement, Disconnect the control board: étape 6, image 3 de 3
    • Disconnect the large connector attached to the right edge of the control board.
  7. WRS315SDHW Control Board Replacement: étape 7, image 1 de 2 WRS315SDHW Control Board Replacement: étape 7, image 2 de 2
    • Disconnect the small connector attached to the left edge of the control board.
  8. WRS315SDHW Control Board Replacement, Remove the control board: étape 8, image 1 de 1
    • Remove the control board.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membre depuis le 04/14/15
15 927 Réputation
89 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
45 membres
705 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 27
Total : 411
