Aller au contenu principal
WRS315SDHW Defrost Heater Replacement
nicO
nicO et 2 autres contributeurs
Dernière mise à jour le June 1, 2023
15 - 30 minutes
Modérée
Use this guide to replace the defrost heater in your Whirlpool WRS315SDHW Refrigerator.
The defrost heater melts frost off the evaporator fins. If your freezer is perpetually frosty, then the defrost heater might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
  1. WRS315SDHW Defrost Heater Replacement, Safety precautions: étape 1, image 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Defrost Heater Replacement, Open the doors: étape 2, image 1 de 3 WRS315SDHW Defrost Heater Replacement, Open the doors: étape 2, image 2 de 3 WRS315SDHW Defrost Heater Replacement, Open the doors: étape 2, image 3 de 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Defrost Heater Replacement, Remove the drawers: étape 3, image 1 de 2 WRS315SDHW Defrost Heater Replacement, Remove the drawers: étape 3, image 2 de 2
    • Remove the drawers and shelves from the freezer section.
  4. WRS315SDHW Defrost Heater Replacement: étape 4, image 1 de 2 WRS315SDHW Defrost Heater Replacement: étape 4, image 2 de 2
    • Remove the screw(s) securing the evaporator cover.
  5. WRS315SDHW Defrost Heater Replacement, Unclip the evaporator cover: étape 5, image 1 de 3 WRS315SDHW Defrost Heater Replacement, Unclip the evaporator cover: étape 5, image 2 de 3 WRS315SDHW Defrost Heater Replacement, Unclip the evaporator cover: étape 5, image 3 de 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. WRS315SDHW Defrost Heater Replacement, Remove the evaporator cover: étape 6, image 1 de 3 WRS315SDHW Defrost Heater Replacement, Remove the evaporator cover: étape 6, image 2 de 3 WRS315SDHW Defrost Heater Replacement, Remove the evaporator cover: étape 6, image 3 de 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. WRS315SDHW Defrost Heater Replacement, Disconnect the defrost heater: étape 7, image 1 de 3 WRS315SDHW Defrost Heater Replacement, Disconnect the defrost heater: étape 7, image 2 de 3 WRS315SDHW Defrost Heater Replacement, Disconnect the defrost heater: étape 7, image 3 de 3
    • Disconnect the two spade connectors attached to the defrost heater.
  8. WRS315SDHW Defrost Heater Replacement, Reposition the cable: étape 8, image 1 de 3 WRS315SDHW Defrost Heater Replacement, Reposition the cable: étape 8, image 2 de 3 WRS315SDHW Defrost Heater Replacement, Reposition the cable: étape 8, image 3 de 3
    • Pull the defrost heater cable out from behind the evaporator.
  9. WRS315SDHW Defrost Heater Replacement, Unfasten the defrost heater bracket: étape 9, image 1 de 1
    • Use a 1/4 inch socket wrench to remove the 16.5 mm-long screw securing the defrost heater bracket.
  10. WRS315SDHW Defrost Heater Replacement, Release the defrost heater bracket: étape 10, image 1 de 2 WRS315SDHW Defrost Heater Replacement, Release the defrost heater bracket: étape 10, image 2 de 2
    • Pull the defrost heater bracket up to release it from its slot in the chassis.
  11. WRS315SDHW Defrost Heater Replacement, Remove the defrost heater: étape 11, image 1 de 3 WRS315SDHW Defrost Heater Replacement, Remove the defrost heater: étape 11, image 2 de 3 WRS315SDHW Defrost Heater Replacement, Remove the defrost heater: étape 11, image 3 de 3
    • Slide the defrost heater from under the evaporator.
    • You may need to pull one end at a time until it's completely removed.
  12. WRS315SDHW Defrost Heater Replacement, Only the defrost heater remains: étape 12, image 1 de 1
    • You're now left with the defrost heater.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membre depuis le 04/14/15
15 927 Réputation
89 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
46 membres
707 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 253
