Aller au contenu principal
WRS315SDHW Door Sensor Replacement
nicO
nicO et 2 autres contributeurs
Dernière mise à jour le June 1, 2023
5 - 15 minutes
Facile
Use this guide to replace the door sensor or door switch in your Whirlpool WRS315SDHW Refrigerator.
The door switch detects whether or not the door is open or if the control board thinks it's open. If you're having trouble dispensing ice/water, or if your door light won't turn off, then your door switch might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Ce dont vous avez besoin
  1. WRS315SDHW Door Sensor Replacement, Open the doors: étape 1, image 1 de 3 WRS315SDHW Door Sensor Replacement, Open the doors: étape 1, image 2 de 3 WRS315SDHW Door Sensor Replacement, Open the doors: étape 1, image 3 de 3
    • Depending on your repair, open one or both doors.
  2. WRS315SDHW Door Sensor Replacement, Unclip the door sensor: étape 2, image 1 de 3 WRS315SDHW Door Sensor Replacement, Unclip the door sensor: étape 2, image 2 de 3 WRS315SDHW Door Sensor Replacement, Unclip the door sensor: étape 2, image 3 de 3
    • Insert a flathead screwdriver, or a similar tool, between the door sensor and the chassis.
    • Pry up to separate the door sensor enough so you can grip it with your fingers.
  3. WRS315SDHW Door Sensor Replacement: étape 3, image 1 de 2 WRS315SDHW Door Sensor Replacement: étape 3, image 2 de 2
    • Pull the door sensor through the chassis enough to access its connector.
    • Disconnect the spade connector attached to the door sensor.
    • Remove the door sensor.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membre depuis le 04/14/15
15 927 Réputation
89 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 4
Total : 80
