Aller au contenu principal
WRS315SDHW Start Relay Assembly Replacement
nicO
nicO et 3 autres contributeurs
Dernière mise à jour le June 1, 2023
15 - 30 minutes
Modérée
Use this guide to replace the start relay assembly in your Whirlpool WRS315SDHW Refrigerator.
The start relay is a combination of the start relay, the overload relay, and the start capacitor, which are responsible for protecting your compressor's circuit. If the fans are running and your compressor won’t start, or if you hear a clicking sound from the unit, your start relay assembly might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
  1. WRS315SDHW Start Relay Assembly Replacement, Safety precautions: étape 1, image 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Start Relay Assembly Replacement, Unfasten the rear panel: étape 2, image 1 de 3 WRS315SDHW Start Relay Assembly Replacement, Unfasten the rear panel: étape 2, image 2 de 3 WRS315SDHW Start Relay Assembly Replacement, Unfasten the rear panel: étape 2, image 3 de 3
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
    • Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
  3. WRS315SDHW Start Relay Assembly Replacement, Remove the rear panel: étape 3, image 1 de 3 WRS315SDHW Start Relay Assembly Replacement, Remove the rear panel: étape 3, image 2 de 3 WRS315SDHW Start Relay Assembly Replacement, Remove the rear panel: étape 3, image 3 de 3
    • Pull the rear panel off the chassis to remove it.
  4. WRS315SDHW Start Relay Assembly Replacement, Disconnect the start relay assembly: étape 4, image 1 de 3 WRS315SDHW Start Relay Assembly Replacement, Disconnect the start relay assembly: étape 4, image 2 de 3 WRS315SDHW Start Relay Assembly Replacement, Disconnect the start relay assembly: étape 4, image 3 de 3
    • Use a flathead screwdriver, or a similar tool, to disconnect the connector attached to the start relay assembly.
  5. WRS315SDHW Start Relay Assembly Replacement, Unclip the start relay assembly: étape 5, image 1 de 3 WRS315SDHW Start Relay Assembly Replacement, Unclip the start relay assembly: étape 5, image 2 de 3 WRS315SDHW Start Relay Assembly Replacement, Unclip the start relay assembly: étape 5, image 3 de 3
    • Pull the metal clip out its hole in the top of the start relay assembly.
    • Rest the clip next to the assembly.
  6. WRS315SDHW Start Relay Assembly Replacement, Remove the start relay assembly: étape 6, image 1 de 3 WRS315SDHW Start Relay Assembly Replacement, Remove the start relay assembly: étape 6, image 2 de 3 WRS315SDHW Start Relay Assembly Replacement, Remove the start relay assembly: étape 6, image 3 de 3
    • Pull the start relay assembly straight off its prongs in the chassis.
    • Remove the start relay assembly.
    • The assembly consists of the start capacitor, start relay, and overload relay.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membre depuis le 04/14/15
15 927 Réputation
89 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 120
