Aller au contenu principal
WRS315SDHW Temperature Control Board Replacement
nicO
nicO et 2 autres contributeurs
Dernière mise à jour le June 1, 2023
10 - 20 minutes
Modérée
Use this guide to replace the temperature control board in your Whirlpool WRS315SDHW Refrigerator.
The temperature control board regulates the temperature throughout the refrigerator. If your refrigerator is not cooling properly, your temperature control board might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
  1. WRS315SDHW Temperature Control Board Replacement, Safety precautions: étape 1, image 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Temperature Control Board Replacement, Open the doors: étape 2, image 1 de 3 WRS315SDHW Temperature Control Board Replacement, Open the doors: étape 2, image 2 de 3 WRS315SDHW Temperature Control Board Replacement, Open the doors: étape 2, image 3 de 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Temperature Control Board Replacement, Unfasten the temperature control board assembly: étape 3, image 1 de 2 WRS315SDHW Temperature Control Board Replacement, Unfasten the temperature control board assembly: étape 3, image 2 de 2
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 22.3 mm-long screw securing the temperature control board assembly.
  4. WRS315SDHW Temperature Control Board Replacement, Reposition the assembly: étape 4, image 1 de 3 WRS315SDHW Temperature Control Board Replacement, Reposition the assembly: étape 4, image 2 de 3 WRS315SDHW Temperature Control Board Replacement, Reposition the assembly: étape 4, image 3 de 3
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. WRS315SDHW Temperature Control Board Replacement, Disconnect the temperature control board: étape 5, image 1 de 3 WRS315SDHW Temperature Control Board Replacement, Disconnect the temperature control board: étape 5, image 2 de 3 WRS315SDHW Temperature Control Board Replacement, Disconnect the temperature control board: étape 5, image 3 de 3
    • Disconnect the two spade connectors attached to the temperature control board assembly.
  6. WRS315SDHW Temperature Control Board Replacement, Remove the assembly: étape 6, image 1 de 1
    • Remove the temperature control board assembly.
  7. WRS315SDHW Temperature Control Board Replacement, Separate the temperature control board: étape 7, image 1 de 3 WRS315SDHW Temperature Control Board Replacement, Separate the temperature control board: étape 7, image 2 de 3 WRS315SDHW Temperature Control Board Replacement, Separate the temperature control board: étape 7, image 3 de 3
    • Use a flathead screwdriver, or a similar tool, to compress the plastic clip securing the temperature control board.
    • Use another flathead screwdriver to pry up the board from its housing.
  8. WRS315SDHW Temperature Control Board Replacement, Remove the temperature control board: étape 8, image 1 de 1
    • Pull the temperature control board straight out of its housing to remove it.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membre depuis le 04/14/15
15 927 Réputation
89 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 118
