Aller au contenu principal
Whirlpool Dryer Control Panel Replacement
Bill Gilbert
Bill Gilbert et un autre contributeur
Dernière mise à jour le October 2, 2024
1 - 2 heures
Modérée
Use this guide to replace the control panel of your Whirlpool Dryer.
The control panel allows you to operate your dryer, select the cycles and monitor the drying time. It's also where the end-of-cycle speaker is located. If you can't set the machine to different cycles or get it to start, this unit may be the problem.
This is a straightforward repair, and there are no especially difficult steps.
This guide will work for most Whirlpool dryers. This guide is written with a model WED87HED dryer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The control panel isn't the "brain" of the machine. The brain is called the Main Board, (a.k.a. Cycle Control Unit — CCU) and is located inside the machine cabinet. To replace the main board, follow this link.
  1. Whirlpool Dryer Control Panel Replacement, Safety Precautions: étape 1, image 1 de 1
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool Dryer Control Panel Replacement, Unfasten the top panel: étape 2, image 1 de 3 Whirlpool Dryer Control Panel Replacement, Unfasten the top panel: étape 2, image 2 de 3 Whirlpool Dryer Control Panel Replacement, Unfasten the top panel: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    FixMat
    $36.95
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
  3. Whirlpool Dryer Control Panel Replacement, Remove the top panel: étape 3, image 1 de 2 Whirlpool Dryer Control Panel Replacement, Remove the top panel: étape 3, image 2 de 2
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool Dryer Control Panel Replacement: étape 4, image 1 de 2 Whirlpool Dryer Control Panel Replacement: étape 4, image 2 de 2
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool Dryer Control Panel Replacement, Disconnect the control panel: étape 5, image 1 de 2 Whirlpool Dryer Control Panel Replacement, Disconnect the control panel: étape 5, image 2 de 2
    • Disconnect the control panel cable from the main board.
  6. Whirlpool Dryer Control Panel Replacement: étape 6, image 1 de 2 Whirlpool Dryer Control Panel Replacement: étape 6, image 2 de 2
    • Disconnect the drum light connector.
  7. Whirlpool Dryer Control Panel Replacement, Unfasten the control panel: étape 7, image 1 de 2 Whirlpool Dryer Control Panel Replacement, Unfasten the control panel: étape 7, image 2 de 2
    • Remove the screws securing the control panel.
  8. Whirlpool Dryer Control Panel Replacement, Remove the control panel: étape 8, image 1 de 3 Whirlpool Dryer Control Panel Replacement, Remove the control panel: étape 8, image 2 de 3 Whirlpool Dryer Control Panel Replacement, Remove the control panel: étape 8, image 3 de 3
    • Lift the control panel up and tilt it away from the chassis to remove it.
    • Make sure to thread the cable through the hole in the chassis.
    • During reassembly, thread the cable through its proper hole before reinstalling the control panel.
  9. Whirlpool Dryer Control Panel Replacement, Remove the wiring harness: étape 9, image 1 de 3 Whirlpool Dryer Control Panel Replacement, Remove the wiring harness: étape 9, image 2 de 3 Whirlpool Dryer Control Panel Replacement, Remove the wiring harness: étape 9, image 3 de 3
    • Disconnect the wiring harness connectors.
    • Lay the control panel down on a towel or other soft surface to perform the next few steps.
  10. Whirlpool Dryer Control Panel Replacement, Unfasten the control board: étape 10, image 1 de 1
    • Remove the screws which secure the front control board to its housing.
  11. Whirlpool Dryer Control Panel Replacement, Remove the control panel unit: étape 11, image 1 de 3 Whirlpool Dryer Control Panel Replacement, Remove the control panel unit: étape 11, image 2 de 3 Whirlpool Dryer Control Panel Replacement, Remove the control panel unit: étape 11, image 3 de 3
    • Lift up the back plate off the control panel and remove it.
    • The control panel is a circuit board attached to a face plate. Replace the entire unit if possible.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membre depuis le 06/30/22
37 545 Réputation
261 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
120 membres
20 086 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 41
30 derniers jours : 124
Total : 1,841
