Aller au contenu principal
Xbox Series S Foot Replacement
Arthur Shi
Arthur Shi
Dernière mise à jour le December 18, 2024
3 - 10 minutes
Facile
If your Xbox Series S rocks when you push on it, a foot is likely missing or damaged. Follow this guide to replace the missing, damaged, or flattened foot.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Xbox Series S Foot Replacement, Set your Xbox down: étape 1, image 1 de 2 Xbox Series S Foot Replacement, Set your Xbox down: étape 1, image 2 de 2
    • Place your Xbox on your work surface so that the foot you're replacing is facing upward.
  2. Xbox Series S Foot Replacement, Pry up the old foot: étape 2, image 1 de 3 Xbox Series S Foot Replacement, Pry up the old foot: étape 2, image 2 de 3 Xbox Series S Foot Replacement, Pry up the old foot: étape 2, image 3 de 3
    • This step shows how to remove a loose foot. If your Xbox is already missing the foot, skip this step!
    • Insert the point of a spudger underneath one end of the foot.
    • Pry up to separate the foot from the Xbox.
    • Remove the foot.
  3. Xbox Series S Foot Replacement, Clean the footwell: étape 3, image 1 de 3 Xbox Series S Foot Replacement, Clean the footwell: étape 3, image 2 de 3 Xbox Series S Foot Replacement, Clean the footwell: étape 3, image 3 de 3
    • Cleaning the footwell will drastically help the new foot to stay on your Xbox.
    • Apply a drop of >70% isopropyl alcohol to the footwell.
    • Use the point of a spudger or a toothpick to scrape and loosen any adhesive residue in the footwell.
    • Wipe the footwell with a lint-free cloth or a coffee filter.
  4. Xbox Series S Foot Replacement, Replace the foot: étape 4, image 1 de 3 Xbox Series S Foot Replacement, Replace the foot: étape 4, image 2 de 3 Xbox Series S Foot Replacement, Replace the foot: étape 4, image 3 de 3
    • Pick up a foot from the replacement sheet.
    • Align the foot in its footwell.
    • Use your finger to press the foot down for ten seconds to secure it onto your Xbox.
If your Xbox is missing additional feet, repeat the procedure to replace them.
Arthur Shi
Membre depuis le 01/03/18
283 132 Réputation
587 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 540 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 22
30 derniers jours : 87
Total : 281
