Aller au contenu principal
Yuneec ST16S Carrying Handle Replacement
Christian Resendes
Christian Resendes et 5 autres contributeurs
Dernière mise à jour le July 1, 2024
10 minutes
Facile
Étudiant en action
This guide explains how to replace the carrying handle on the Yuneec ST16S. The handle allows you to carry the device with ease. You can find out more checking the troubleshooting page.
Ce dont vous avez besoin
Outils
  1. Yuneec ST16S Carrying Handle Replacement, Battery: étape 1, image 1 de 1
    • Hold down the button located above the battery while applying downward pressure to the battery.
  2. Yuneec ST16S Carrying Handle Replacement: étape 2, image 1 de 2 Yuneec ST16S Carrying Handle Replacement: étape 2, image 2 de 2
    • While still holding down the button, slide the battery out of its slot.
  3. Yuneec ST16S Carrying Handle Replacement, Backplate: étape 3, image 1 de 1
    • Remove the single screw from the battery compartment.
  4. Yuneec ST16S Carrying Handle Replacement: étape 4, image 1 de 2 Yuneec ST16S Carrying Handle Replacement: étape 4, image 2 de 2
    • Remove the rubber bumpers from the back of the device using a spudger.
  5. Yuneec ST16S Carrying Handle Replacement: étape 5, image 1 de 2 Yuneec ST16S Carrying Handle Replacement: étape 5, image 2 de 2
    • Remove the two screws located under each of the rubber bumpers.
  6. Yuneec ST16S Carrying Handle Replacement: étape 6, image 1 de 3 Yuneec ST16S Carrying Handle Replacement: étape 6, image 2 de 3 Yuneec ST16S Carrying Handle Replacement: étape 6, image 3 de 3
    • Remove the three screws along the top of the device.
  7. Yuneec ST16S Carrying Handle Replacement: étape 7, image 1 de 2 Yuneec ST16S Carrying Handle Replacement: étape 7, image 2 de 2
    • Carefully remove the backplate from the device.
  8. Yuneec ST16S Carrying Handle Replacement, Carrying Handle: étape 8, image 1 de 2 Yuneec ST16S Carrying Handle Replacement, Carrying Handle: étape 8, image 2 de 2
    • Remove the screws from the clips on both ends of the handle.
  9. Yuneec ST16S Carrying Handle Replacement: étape 9, image 1 de 2 Yuneec ST16S Carrying Handle Replacement: étape 9, image 2 de 2
    • Slide the clips away from the handle.
  10. Yuneec ST16S Carrying Handle Replacement: étape 10, image 1 de 1
    • Remove the handle from the device.
Christian Resendes
Membre depuis le 10/28/21
589 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021 Membre de l'équipe UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G2
3 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 79
