Aller au contenu principal
iMac G5 20" Model A1145 Optical Drive Replacement
Andrew Bookholt
Andrew Bookholt et 4 autres contributeurs
Dernière mise à jour le October 15, 2013
Aucune estimation
Modérée
Use this guide to replace a broken optical drive.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. iMac G5 20" Model A1145 Optical Drive Replacement, Access Door: étape 1, image 1 de 1
    • Orient the iMac face-side down on a table with the bottom edge facing yourself.
    • Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
    • The screws are captive in the access door.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
  2. iMac G5 20" Model A1145 Optical Drive Replacement: étape 2, image 1 de 1
    • Remove the access door.
  3. iMac G5 20" Model A1145 Optical Drive Replacement, Front Bezel: étape 3, image 1 de 1
    • Remove the three T8 Torx screws securing the front bezel to the rear case along the lower edge of the iMac.
  4. iMac G5 20" Model A1145 Optical Drive Replacement: étape 4, image 1 de 2 iMac G5 20" Model A1145 Optical Drive Replacement: étape 4, image 2 de 2
    • Turn the computer over.
    • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
  5. iMac G5 20" Model A1145 Optical Drive Replacement: étape 5, image 1 de 1
    • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
  6. iMac G5 20" Model A1145 Optical Drive Replacement: étape 6, image 1 de 3 iMac G5 20" Model A1145 Optical Drive Replacement: étape 6, image 2 de 3 iMac G5 20" Model A1145 Optical Drive Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    • Re-orient your iMac so it sits upright on the stand.
    • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
    • Push the card toward the top of the iMac to release the front bezel latch.
    • Pull the front bezel away from the rear case.
    • Repeat this process for the other side of the front bezel.
    • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
    • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
    • Alternatively, you can use a strong magnet by holding it to the front top left/right corner of the display. You will hear a snapping sound when the hatch is released.
  7. iMac G5 20" Model A1145 Optical Drive Replacement: étape 7, image 1 de 1
    • Lay your iMac stand-side down on a table.
    • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
    • Lay the front bezel above the rest of the iMac.
  8. iMac G5 20" Model A1145 Optical Drive Replacement: étape 8, image 1 de 1
    • If necessary, remove the piece of kapton tape wrapped around the microphone and camera connectors.
  9. iMac G5 20" Model A1145 Optical Drive Replacement: étape 9, image 1 de 2 iMac G5 20" Model A1145 Optical Drive Replacement: étape 9, image 2 de 2
    • Disconnect both the camera and microphone cables.
  10. iMac G5 20" Model A1145 Optical Drive Replacement, Lower EMI Shield: étape 10, image 1 de 1
    • Peel the lower EMI shield off the lower edge of the iMac and off the two vertical 4" sections on either side of the iMac.
    • It is not necessary to peel the lower EMI shield off the display.
  11. iMac G5 20" Model A1145 Optical Drive Replacement: étape 11, image 1 de 1
    • Tape the lower EMI shield up against the face of the display to keep it out of the way while you work.
  12. iMac G5 20" Model A1145 Optical Drive Replacement, Display: étape 12, image 1 de 1
    • Remove the two T6 Torx screws securing the display data cable connector to the logic board.
  13. iMac G5 20" Model A1145 Optical Drive Replacement: étape 13, image 1 de 1
    • To disconnect the display data cable, grab its connector's black tab and pull it away from the face of the logic board.
  14. iMac G5 20" Model A1145 Optical Drive Replacement: étape 14, image 1 de 1
    • Peel back the two EMI tape strips from the left and right edges of the display.
    • During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
  15. iMac G5 20" Model A1145 Optical Drive Replacement: étape 15, image 1 de 2 iMac G5 20" Model A1145 Optical Drive Replacement: étape 15, image 2 de 2
    • Remove the four recessed T10 Torx screws securing the display to the rear case.
    • Bit drivers tend to be too short to reach these screws. Be sure to have a magnetic thin-shafted T10 Torx screwdriver on hand.
  16. iMac G5 20" Model A1145 Optical Drive Replacement: étape 16, image 1 de 1
    • Lift the lower edge of the display slightly out of the rear case.
    • Disconnect both inverter cables (shown in red) by pulling their connectors toward the bottom edge of your iMac.
  17. iMac G5 20" Model A1145 Optical Drive Replacement: étape 17, image 1 de 1
    • Lift the display until it is nearly perpendicular to the rear case.
    • Disconnect the remaining two inverter cables (shown in red) by pulling their connectors toward the top edge of your iMac.
  18. iMac G5 20" Model A1145 Optical Drive Replacement: étape 18, image 1 de 1
    • While holding the display perpendicular to the rear case, pull it upward to peel off the EMI shield stuck to its upper edge.
  19. iMac G5 20" Model A1145 Optical Drive Replacement, Optical Drive: étape 19, image 1 de 1
    • Disconnect the optical drive thermal sensor by pulling its cable toward the left edge of your iMac.
  20. iMac G5 20" Model A1145 Optical Drive Replacement: étape 20, image 1 de 1
    • Remove the two T6 Torx screws holding the optical drive connector to the logic board.
  21. iMac G5 20" Model A1145 Optical Drive Replacement: étape 21, image 1 de 1
    • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
    • It is helpful to insert the spudger under the top or bottom edge of the optical drive connector and twist to separate the connector from the logic board.
  22. iMac G5 20" Model A1145 Optical Drive Replacement: étape 22, image 1 de 1
    • Apple's "engineers" didn't learn much about deflection and material stiffness when they went to "college", so this optical drive is particularly difficult to remove because the bracket flexes too much. The next few steps require some patience and a good amount of force.
    • Insert the flat end of a spudger into the gap between the optical drive and its bracket until it contacts the chassis.
    • Grab the spudger as close to the surface of the optical drive as you can, then depress the release tab with your thumb while pulling toward yourself.
    • The wedge shape of the spudger may cause it to slip out of the gap toward yourself. Be sure to press the spudger in toward the rear case while squeezing the release tab.
  23. iMac G5 20" Model A1145 Optical Drive Replacement: étape 23, image 1 de 1
    • To avoid the screws falling behind the logic board, lay your iMac stand-side down on a table.
    • Remove the two T10 Torx screws from the lower edge of the optical drive.
  24. iMac G5 20" Model A1145 Optical Drive Replacement: étape 24, image 1 de 1
    • Use the flat end of a spudger to press the bottom edge of the lower optical drive bracket release tab toward the lower edge of the iMac.
    • The optical drive should now be free from the rear case.
    • Maneuver the optical drive out of the rear case, minding the two plastic pins molded into the rear case near the open end of the optical drive that can break off.
  25. iMac G5 20" Model A1145 Optical Drive Replacement: étape 25, image 1 de 1
  26. iMac G5 20" Model A1145 Optical Drive Replacement, Optical Drive: étape 26, image 1 de 1
    • Remove the two T6 Torx screws securing the optical drive cable to the optical drive.
  27. iMac G5 20" Model A1145 Optical Drive Replacement: étape 27, image 1 de 2 iMac G5 20" Model A1145 Optical Drive Replacement: étape 27, image 2 de 2
    • Insert the flat end of a spudger into the gap between the optical drive cable connector and the optical drive.
    • Twist the spudger to separate the connector from the optical drive.
    • Repeat this process for both sides of the connector.
    • Pull the optical drive cable connector away from the optical drive.
  28. iMac G5 20" Model A1145 Optical Drive Replacement: étape 28, image 1 de 1
    • Use the flat end of a spudger to remove the small pieces of EMI foam from the underside of the optical drive.
    • Don't forget to transfer these to your new drive.
  29. iMac G5 20" Model A1145 Optical Drive Replacement: étape 29, image 1 de 1
    • Use the flat end of a spudger to remove the long strip of EMI foam from the underside of the optical drive.
    • Don't forget to transfer this to your new drive.
  30. iMac G5 20" Model A1145 Optical Drive Replacement: étape 30, image 1 de 1
    • Remove the two T10 Torx screws from the side of your optical drive.
  31. iMac G5 20" Model A1145 Optical Drive Replacement: étape 31, image 1 de 1
    • Use the tip of a spudger to push the two optical drive bracket tabs out of their slots in the top of the optical drive.
  32. iMac G5 20" Model A1145 Optical Drive Replacement: étape 32, image 1 de 1
    • Using the tip of a spudger, press the optical drive bracket tab out of its slot on the side of the optical drive.
  33. iMac G5 20" Model A1145 Optical Drive Replacement: étape 33, image 1 de 1
    • Use the tip of a spudger to press the optical drive bracket tabs out of the slots in the top of the optical drive.
  34. iMac G5 20" Model A1145 Optical Drive Replacement: étape 34, image 1 de 1
    • Pull the optical drive bracket toward the open end of the optical drive to free it from the optical drive.
  35. iMac G5 20" Model A1145 Optical Drive Replacement: étape 35, image 1 de 1
    • Use the flat end of a spudger to pry the optical drive thermal sensor off the adhesive securing it to the optical drive.
    • If you have a disk or anything else stuck inside your optical drive, we have a guide to fix it.
9 autres ont terminé cette réparation.
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 10
Total : 18,488
