Aller au contenu principal
Depth Sensor Node Enclosure Assembly
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 22
Étape 22
Depth Sensor Node Enclosure Assembly, Adjusting Solar Charger Potentiometer: étape 0, image 1 de 3 Depth Sensor Node Enclosure Assembly, Adjusting Solar Charger Potentiometer: étape 0, image 2 de 3 Depth Sensor Node Enclosure Assembly, Adjusting Solar Charger Potentiometer: étape 0, image 3 de 3
  • Obtain USB power supply, plug into a laptop, and set output to 5.9V
  • Check the voltage with a voltmeter (you may have to set the power supply to ~5.8V for the voltmeter to read 5.9V)
  • Plug in the green terminal block from the power supply into the Open-Storm board solar port.
  • Confirm the solar charge LED is off.
  • Plug in a dead battery to the battery port. This step will not work with a charged battery
  • CAREFULLY turn the silver potentiometer next to the charge controller IC with a small flathead screw driver until the charge light turns on.
  • Although the screw has a phillip screw head, using a phillip screwdriver may damage the potentiometer. The hole in the center is too shallow for most screwdrivers. It is easier to use a flathead screwdriver!
  • Resource: 1. How to Select MPP Voltage on a Solar Charge Controller 2. Sunny Buddy Solar Charger V13 Hookup Guide
Insérez ici votre traduction
