Aller au contenu principal
Remplacement de la batterie du Samsung Galaxy S20 Ultra
Anglais
Français
Traduction de l’étape 3
Étape 3
Samsung Galaxy S20 Ultra Battery Replacement, Remove the battery: étape 0, image 1 de 1
Remove the battery
  • Remove the battery.
  • Peel up and/or scrape away any remaining battery adhesive before cleaning the battery well surface with isopropyl alcohol and a lint free cloth.
  • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
  • During reassembly, if your new battery doesn't come with pre-applied adhesive, apply some to the well. Then, firmly press the new battery into place.
  • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
Enlevez la batterie.
Décollez et/ou grattez les résidus d'adhésif avant de bien nettoyer le compartiment de la batterie avec de l'alcool isopropylique et un chiffon non pelucheux.
Si votre nouvelle batterie n'est pas munie d'adhésif prédécoupé, posez-en au fond du compartiment. Puis installez la batterie et appuyez fermement pour qu'elle adhère.
Attention : Ne réutilisez jamais une batterie, car c'est dangereux. Remplacez-la par une neuve.
[title] Remove the battery
[* black] Remove the battery.
[* black] Peel up and/or scrape away any remaining battery adhesive before cleaning the battery well surface with isopropyl alcohol and a lint free cloth.
+[* black] If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
[* icon_reminder] During reassembly, if your new battery doesn't come with pre-applied adhesive, apply some to the well. Then, firmly press the new battery into place.
-[* icon_caution] ***Caution:*** Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
+[* icon_caution] Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
