Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 14
Étape 14
On the lower PCB, we get a good look at one of  the two analog joysticks. Its spring-loaded movement is tracked by two potentiometers that measure degrees of tilt in two axes. Potentiometers are analog devices that vary their resistance with position—this makes for an ideal low-power sensor, as only a small amount of power is required to measure resistance. With a quick flick of a plastic opening tool, we release the plastic clips holding the shoulder buttons spring assembly in place.
  • On the lower PCB, we get a good look at one of the two analog joysticks. Its spring-loaded movement is tracked by two potentiometers that measure degrees of tilt in two axes.
  • Potentiometers are analog devices that vary their resistance with position—this makes for an ideal low-power sensor, as only a small amount of power is required to measure resistance.
  • With a quick flick of a plastic opening tool, we release the plastic clips holding the shoulder buttons spring assembly in place.
Insérez ici votre traduction
