Aller au contenu principal
Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement: étape 0, image 1 de 2 Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement: étape 0, image 2 de 2
  • Lift the latch holding down the ribbon cable connected to the touch pad.
  • When inserting the cable back, ensure that it goes under the white indents.
  • Remove the three screws holding down the bracket on the bottom portion of the touch pad using a Phillips #0 screwdriver.
  • Remove the four screws holding down the bracket on the upper portion of the touch pad using a Phillips #0 screwdriver.
  • Remove the bracket on the bottom portion of the touchpad by carefully peeling it away, as it is held by adhesives, then set it aside.
Insérez ici votre traduction
