Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 14 tutoriels qui comprennent cette étape.
Traduction de l’étape 2
Étape 2
Loosen the display
Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
+ | [title] Loosen the display |
[* black] Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle. | |
[* icon_caution] Be very careful when opening the iPhone so that the cables under the display are not severed. | |
[* icon_note] There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly. It may help to rock the suction cup back and forth to remove the display assembly. | |
[* black] Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly. | |
[* icon_note] If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape or packing tape may be used. |
