Aller au contenu principal
Remplacement de la prise Jack du Nexus 5
Anglais
Français
Traduction de l’étape 1
Étape 1
Nexus 5 Headphone Jack Replacement, Remove the Headphone Jack: étape 0, image 1 de 1
  • In this image, the motherboard has been removed. This is NOT required as part of this guide.
  • Use a spudger or tweezers to pull the headphone jack upward and out of the phone.
  • The headphone jack is secured by the spring tension of its contacts to the motherboard.
  • It is also secured by adhesive below it.
  • Place the new headphone jack by orienting it like the old one and pressing it gently down into the phone.
  • It is a snug fit due to the tension of its sprung contacts.
La carte mère a été retirée sur la seconde photo. Ce retrait n'est PAS une étape nécessaire de ce guide.
Servez-vous d'une spatule ou d'une pincette pour tirer la prise Jack vers le haut et hors du téléphone.
La prise Jack est fixée à la carte mère par la tension des ressorts de ses contacts.
De plus, il y a en dessous une couche d'adhésif.
Posez la nouvelle prise Jack dans la même position que l'ancienne et appuyez délicatement dessus pour l'insérer dans le téléphone.
L'emplacement est bien ajusté en raison de la tension des contacts à ressort.
[title] Remove the Headphone Jack
-[* icon_reminder] In the second image, the motherboard has been removed. This is NOT required as part of this guide.
-[* black] Use a [https://www.ifixit.com/Tools/Spudger/IF145-002-2|Spudger] or [product|IF145-020-2|Tweezers] to pull the headphone jack upward and out of the phone.
+[* icon_reminder] In this image, the motherboard has been removed. This is NOT required as part of this guide.
+[* black] Use a spudger or [product|IF145-020|tweezers] to pull the headphone jack upward and out of the phone.
[* icon_note] The headphone jack is secured by the spring tension of its contacts to the motherboard.
[* icon_note] It is also secured by adhesive below it.
[* black] Place the new headphone jack by orienting it like the old one and pressing it gently down into the phone.
[* icon_note] It is a snug fit due to the tension of its sprung contacts.
