Aller au contenu principal
Polaroid LCD-0700P Case Replacement
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Polaroid LCD-0700P Case Replacement: étape 0, image 1 de 2 Polaroid LCD-0700P Case Replacement: étape 0, image 2 de 2
  • Turn the device so that the underside faces you, and the edge where the case and device bind, faces upward. The opening of the device should be face down.
  • In this position you will see a crease line between the device and the top cover. Gently Insert your blue plastic opening tool into the crack of the crease line, between the front and back cover to separate them.
  • Be careful when separating the front and back covers, as the two are held together by a thin wire.
  • Separate the halves of the case.
Insérez ici votre traduction
