Aller au contenu principal
Acer Iconia A100 I/O Board Replacement
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Acer Iconia A100 I/O Board Replacement: étape 0, image 1 de 3 Acer Iconia A100 I/O Board Replacement: étape 0, image 2 de 3 Acer Iconia A100 I/O Board Replacement: étape 0, image 3 de 3
  • Locate the two connectors at each end of the FPC.
  • Use the flat edge of a spudger tool or your fingernail to gently pry each connector straight upwards out of its socket, then remove the FPC cable from the unit.
  • While a metal spudger tool is shown here, it is best to use a plastic spudger / opening tool when possible, and only use a metal spudger as a last resort!
  • You should now see the yellow-colored strip on the metal base marking the location of the FPC
Insérez ici votre traduction
