Aller au contenu principal
Table des matières
Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
Laptop overheating
Device becomes excessively heated to the point where the computer may shut down
Cleaning Radiator
One of the biggest issues is that dust collects in the radiator. Follow this guide to access the radiator. Once you have access to it gently spray with canned air.
Computer will not turn on
Screen is black and power light is not illuminated
Remove the battery and directly plug into the outlet with the power cord
If the computer powers on without the battery and just the cord, then the battery is dead and mus be replaced.
Hard drive failing
"Computer is making odd sounds"
Finding possible causes
When the drive powers on you should hear a whirling noise coming from the bottom of the computer. When starting up the computer hold down the F2 key until a terminal screen (Black screen with white and blue computer text) appears. Select "Boot" from the top menu and from the list below select "hard disk drives". If the hard drive has not failed, then it should be listed. If drive shows up but does not fully boot then you must enter safe mode by rebooting the computer and holding the shift key. You will notice an advanced boot options menu, select "safe mode" and boot should become successful. If this does not work then you will need to buy a new hard drive.
Rebooting Computer
Does the screen say check OS when booting? If so, then your operating systems is corrupt and you must enter safe mode by rebooting computer and holding down shift key for 10 seconds. You will notice an advanced boot options menu, select "safe mode" and boot should become successful. If this does not work then you will need to buy a new hard drive.
Computer powers on but screen is black
Computer is working, screen is not
Test on secondary monitor
Obtain Video Graphics Array (VGA) cable and plug into VGA or PC port to bottom left port and secondary monitor, then boot computer. You should be able to see the computer appear on secondary monitor. If this happens you must replace this part.
Test for loose connection
Move monitor at different angles to see if there is a loose connection. If that is the case then you will need this part.
USB port not working
Connection to USB devices stopped functioning
Testing the USB device
Test your USB device on another device to ensure that it is not the problem, and then try another USB port on your device. If it still does not work then re-install drivers by locating device manager in the start menu. Select "human interface devices", right click in the drop down menu and choose "update driver software". After it has installed restart computer.
Megan Nelson
Membre depuis le 10/05/15
296 Réputation
2 tutoriels rédigés
Équipe
1 commentaire
My Dell m330 is not working whenever i turn its power button on the Led start blinking but there is no noise no symbol of system working i also tried another battery and all method kindly help me
aan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 3
Total : 1,610
