Aller au contenu principal
Table des matières
Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
The Speaker Won't Charge
The device will not charge when connected to a charging port.
Dust in the charging port
The accumulation of dust and grime within the charging port of devices such as this is a common issue that can affect the devices charging capabilities. Use a small pick tool or air to clean out the port. In addition, use a dust blower to get small particles of dust out of the port
Faulty power adapter
A faulty power adapter is a common symptom of a device not charging. The Heyday Wireless Speaker 8125 is fitted with a common micro USB charging cable and if this cable is ruined in any way, the device will likely not charge. To fix this issue, a replacement micro USB cable may be required.
Damaged charging port
Broken components inhibit the device from charging. You will need to open up the speaker and replace the charging port. Refer to the charging port replacement guide.
The Battery Won't Hold a Charge
Even when charged, the device rapidly loses battery power.
Faulty battery
If the speaker is plugged in and the lights are indicating charging but the speaker won’t remain on without the power adapter, regardless of charging time, the battery is faulty. You will need to open up the speaker, remove the old battery and connect a new battery. Refer to the battery replacement guide.
Battery is at the End of its Life
It is possible that the device's battery life has shortened over time with use. This particular wireless speaker will last 8 hours when in use, but if your device lasts less than 6 hours, the battery life may be shortened. If this is the case, the battery will have to be replaced. Please refer to the battery replacement guide.
Buttons are Unresponsive
The buttons won't respond or appear to be stuck and/or unusable.
The Speaker May Need a Factory Reset
The speaker may need to have a factory reset in order for the buttons to become responsive again. In order to factory reset the device, make sure the device is turned off. You will need to hold down the power button for 10 seconds. This should help reset the settings.
Buttons are Dirty
Buttons may be stuck in place due to debris clogged within the button housing. In order to clean under the buttons, you will need to open up the device, locate the buttons and proceed to clean under them. If the problem persists, you may need to proceed to replace the buttons on your device. Refer to the button replacement guide.
Damaged Buttons
It is also possible that the buttons have been rendered unusable due to them being damaged. Whether the buttons have become worn from use or they have been damaged in some other way, the buttons will likely need to be replaced. Please refer to the button replacement guide.
Audio is Distorted
When in use, the device's audio sounds muffled or distorted.
Damaged Speaker
Common indicators of a punctured or blown-out speaker are an unpleasant buzzing sound or scratching sound. If these symptoms occur, the speaker cone will have to be replaced. To replace the speaker refer to the speaker cone replacement guide.
Loose Or Bent Wires
Loose connections and bent wires can inhibit the speaker’s performance. You will have to open up the device and properly connect wires, or replace the severely bent wires. Refer to the speaker replacement guide to check for crimped or damaged wires or to see if any connectors are detached.
Device Has trouble Pairing to other Devices Using Bluetooth
When attempting to connect the device via Bluetooth, the device cannot be found.
The Device Isn't Charged
The speaker may not be charged. The speaker has an internal battery that can be charged using the included cable. If the battery is dead the device may not connect to Bluetooth.
The Speaker is Out of Range
The device may be out of range. If the device is out of range, it won't connect to Bluetooth. Normally Bluetooth becomes out of range beyond 10 feet. Make sure you are close enough to the device that Bluetooth is in range.
The Speaker is Already Paired with Another Device
If the device is still paired to another device you will need to unpair from one device to pair it with another. A rapid flashing white light on the speaker will indicate that it is in pairing mode, in this moment you will need to use Bluetooth settings on your smart device to pair with HEYDAY SPEAKER 06. Once the flashing white light turns solid white it an indicated that both devices are Bluetooth connected.
Mariah Perfect
Membre depuis le 01/20/23
147 Réputation
1 tutoriel rédigé
Équipe
2 commentaires
I have had a HeyDay speaker that I used solely for my HP desktop computer for years then all the sudden the sounds were garbled and cutting in and out. I thought that my speaker was old so I purchased a new one just a few days ago. Again, I have paired it with my desktop computer but the brand new one is garbled also. I have not added any new blue tooth devices so I don't understand why the sound isn't working.
Is it possible for you to help me with this?
I am working with HP desktop Windows 11.
Thank YOU so very much for any assistance.
Sandy
Sandy Murphy - Réponse
YES it is fully charged :-)
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 34
Total : 2,297
