Aller au contenu principal
Table des matières
Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
If you see "No Device Found" when trying to connect to your Polk Omni S2 via the Polk App, follow this troubleshooting guide.
Router is Out-Of-Date
Make sure your router is up to date. If it is older, you might need to upgrade to a new router. Polk recommends an "802.11n" type router or better, but an "802.11g" router or better is required. Pay attention to the last letter, as all router types start with "802.11". Also note that router types aren't ordered alphabetically (802.11ac is better than 802.11n, for instance).
Poor Wi-Fi Signal
Make sure your speaker is in an area with a strong Wi-Fi signal. If you're setting up your speaker, try to set it up near your router.
Ensure other wireless devices like phones and computers aren't interfering with the signal by disconnecting devices that aren't in use from your network.
Speaker Needs To Be Reset
You can try resetting your speaker to factory settings by holding the Wi-Fi button down for 15 seconds. You will hear three sets of tones: the first two are for Wi-Fi setup, while the third and final set of tones indicates that the speaker is being reset. Once the speaker has been reset to factory default settings, try setting up again on your network.
Network Name Has Special Characters
Some users have reported that having special characters (<>^%, etc.) in your network name makes the network undetectable by the Polk App. If your network's name has special characters, try changing it to one with only letters and numbers, no special characters or spaces. For most routers, you can change your network's name using your router's administrator page or through your router's mobile app.
Network Bands Have the Same Name (Dual-Band Only)
Users with a dual-band router (2.4GHz and 5GHz) will have two different networks: one for the 2.4GHz band, and one for the 5GHz band. Some users with these types of routers have reported that if these two networks have the same name, the speaker won't be detected by the Polk App. Try changing the names of the networks so that they are different (but don't use special characters, as noted above). For most routers, you can change your network's name using your router's administrator page or through your router's mobile app.
Speaker is Connected to 5GHz Band (Dual-Band Only)
Users with a dual-band router (2.4GHz and 5GHz) will have two different networks: one for the 2.4GHz band, and one for the 5GHz band. For users with these types of networks, it is recommended to connect to the 2.4GHz band. If your speaker is connected to the 5GHz band, disconnect it and connect instead to the 2.4GHz band (make sure the two bands have different names, as noted above).
Jameson Hall
Membre depuis le 10/18/24
147 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 1-4, Konn Fall 2024 Membre de l'équipe UMass Dartmouth, Team 1-4, Konn Fall 2024
UMASSD-KONN-F24S1G4
4 membres
7 tutoriels rédigés
2 commentaires
Check your router: Make sure your router is up to date. If it is older, you might need to upgrade to a new router or add more access points.
Check your location: Make sure your speaker is in an area with a strong Wi-Fi signal. If you're setting up your speaker, try to set it up near your router.
Check for interference: Ensure other wireless devices like phones and computers aren't interfering with the signal.
Resetting your speaker: You can try resetting your speaker to factory settings and setting it up again on your network.
PaulSM - Réponse
Signs it is a connection error
Flashing light indicator- The LED on the speaker might be flashing, which could be an indicator of a connection error
Device not detected on the app- If the speaker isn't showing up on the app or your network, it may not be connected properly
Unstable connection- The speaker might connect briefly but then lose connection
Incorrect Wifi Frequency- Might have problems with 5GHz networks, it generally works better with 2.4GHz
"Network Conflicts: Other devices may interfere, or the router settings may be blocking the device.
Solution: Try giving the speaker a static IP address via your router settings or disabling any firewall settings temporarily.
Firmware Issues: Outdated firmware could cause connectivity issues.
Solution: Check if the speaker's firmware is up-to-date through the Polk app or contact Polk support."
Mickey - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 102
