Aller au contenu principal
La GoPro Hero3+ Black Edition peut être identifiée par son numéro de modèle : CHDHX-302. C'est une caméra de 8ème génération, sortie en octobre 2013. La GoPro Hero3+ Black Edition a la fonction WiFi, et une résolution max de 4K
20 questions Voir tout
HDMI port has caved in. How do I fix it?
My HDMI port broke and needs to be repaired. I'm not sure if I am going to have to solder the connections or just use some crazy glue. Im scared, actually terrified of tearing it down then realizing that I cant fix it with my limited knowledge of and experience with soldering very small connections, and etc. Anyone that can give me any advice at all concerning this would be greatly appreciated.
Thank You
mishmael
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Réponse la plus utile
There is a take apart video of a fellow that had the same problem with the USB connector. When his disassemble his cam and got to it, the pads were lifted from the motherboard and because of the compactness of it, there is no way to repair that. A new mobo will solve the problem.
Indice 2
3 commentaires:
Mobo ? What's a Mobo ?
par
motherboartd
par
Oh ok I'm not sure if I am going to replace the entire motherboard that sounds expensive
par
mishmael, remove the logic board by using this guide. That is the easy part, the hard part will be to source the port and find somebody that can microsolder. I'd try places like Digikey or Mouser to try and find a replacement. There is plenty of space to solder for the right person. No you cannot use crazy glue. If you want to go and replace the motherboard, it is available right here
Image Main circuit board assembly for the Black Edition of the GoPro Hero3
Produit
GoPro Hero3 Black Motherboard
$19.99
Indice 2
2 commentaires:
The parts are fine the port is in great shape just need to micro solder but I'm also terrified of opening it up
par
mishmael254 got to start somewhere to repair it. If you do not think you can do it, check some of the numerous GoPro repair service centers online.
par
Ajouter une réponse
mishmael sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 3,994
