Aller au contenu principal
Android's 4.4 OS with a 1600 x 2560 pixel resolution.
Green lines appear quickly and device restart
I had this problem a while ago and i live with it. Problem some and dissappear.
You can watch the video link.
I chanhe the software and the same problem appeared. I install the stock Rom and problem did not disappear. I tried other Android roms and same problem. Most of the time problem appeard when battery is low. Most of the time when problem happens my device restart.
https://youtu.be/mKiJAvxAnc0
Samsung galaxy tab s 8.4 lte
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
What is possible fix for this?
par
Ajouter un commentaire
1 Réponse
Your batery may not be providing enough voltage. Try plugging it into a wall charger, with the battery out. Does it do the same?
Edit: I dont see the restart happening.
Indice 0
2 commentaires:
Before i record the video device restarted twice(sometimes it doesn't restart) . As well as for plugin the charger i can't tell now, i will check more than once. Also how can i be sure if the battery does not provide enough voltage?
par
use a multimeter if you have one, if not then try something else
par
Ajouter une réponse
Teto Cv sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 351
